Cannot create Piston
#21
Hello, again.
I’ve tried deleting everything and re-installing both manually and via GitHub. Results are identical: still cannot create a piston.
Unless someone can provide some guidance, I’m going to have to abandon efforts to use webCoRE. I am disappointed that I seem like I’m one of the few folks who have trouble.
Thanks for any guidance…
#22
you have two hubs for the same location? why is that?
#23
No—different locations.
#24
HA! Success at last…
I stumbled into the solution.
I had been logging in to the SmartThings IDE at https://graph.api.smartthings.com/
I decided to try rebooting the hub from there, but when I clicked on My Hubs, I got a message that I didn’t own any. Which seemed strange. In searching for how to fix that, I found a suggestion to log in to the IDE at https://graph-na02-useast1.api.smartthings.com/ide/
When I did that, I found My Hubs properly listed. I then got into My SmartApps which needed to have some of the webCore apps reloaded. I did that, re-installed webCore on my phone, and, voila, “create a new piston” worked!!
Maybe this info will help someone else.
And, I’d be grateful if someone could explain the differ access sites to the IDE.
#25
Everyone should use the following link to login to IDE:
https://account.smartthings.com
It will take you to the correct shard that you are on.
#26
OK. Good to know. Thanks.
