I have a simple webcore piston that I push the smarthing button and i want it to tell a joke but no sound…I added turning a light on to piston and that works. I look at tracing and it says it did the echo speak. I have gone to the echo speak app on the phone and can do the “test” in echo speak and i hear the echo…it just wont do it from webcore. I have followed steps for installing echo speak multiple times…
I did try and uninstall echo speak app and it never would uninstall…i slid the on off to off and reinstalled again and I’m using that one…which again I can hear using the test
(PUT YOUR INFO HERE)
no sound
11/25/2019, 8:12:41 AM +957ms
+1ms ╔Received event [den button].button = pushed with a delay of 84ms
+77ms ║RunTime Analysis CS > 17ms > PS > 25ms > PE > 35ms > CE
+79ms ║Runtime (36504 bytes) successfully initialized in 25ms (v0.3.110.20191009) (77ms)
+87ms ║║Comparison (enum) pushed gets (string) pushed = true (1ms)
+88ms ║║Condition #2 evaluated true (4ms)
+89ms ║║Condition group #1 evaluated true (state did not change) (6ms)
+91ms ║║Cancelling statement #3’s schedules…
+106ms ║║Executed physical command [Den Zooz ZEN23].on() (10ms)
+106ms ║║Executed [Den Zooz ZEN23].on (12ms)
+114ms ║║Skipped execution of physical command [Den Zooz ZEN23].off([]) because it would make no change to the device. (3ms)
+115ms ║║Executed [Den Zooz ZEN23].off (5ms)
+254ms ║║Executed physical command [Echo - Tims’s Echo Dot Den].playJoke() (137ms)
+255ms ║║Executed [Echo - Tims’s Echo Dot Den].playJoke (139ms)
+257ms ║╚Execution stage complete. (177ms)
+258ms ╚Event processed successfully (258ms)
