Hi there,
I find there to be multiple ways to test for idleness, and having been plunged into darkness while showering on a couple of occasions, I’m developing the idea that I might have picked the wrong one. Which of these should work, and which do you recommend?
- Wait, then turn off
This is the latest thing I’ve tried and seems to work, ie. it restarts the timer if motion is detected in the meantime.
- Stays inactive for…
I found that with this option, once a timer was set up, any future motion would not unset it, or rather what seems to happen is that a pair of becomes-active, becomes-inactive events while the timer was running would result in a timer running from the original start time, not the revised start time, so the on-time was not extended.
- Does not change for…
This was my first attempt when I didn’t really know what I was doing (well, I still don’t!), and it didn’t seem to trigger at all. I wonder if maybe it’s because it’s only checking states, not an event?
and didn’t even know there were other ways to do it. We have a motion sensor in the kitchen and it seems to work. The light does not shut off while we’re in there.
