Apologies this is not really a webcore issue, but thought someone on here may be able to help.
I purchased a number of Fibaro dimmer 2’s about 12 months ago and have been using them with no problems. Today I tried to install a new (sealed never used) one for my porch light.
On powering on, it went through the self calibrate ok. But when I tried to add it to ST via the legacy app it couldn’t find it. Trying using the new app, failed at first, asked if I wanted to retry, then found it. However, I can not operate the device through either ST apps.
I’ve tried a second one and tried the pairing process just 1m from the hub with the same problem.
I’ve noticed if I compare the device with a working one in the ST IDE there are some differences new vs old
status - online vs active
data - “network securitylevel: ZWAVE_S0_FAILED” vs “no data found for device” I googled the networksecurity level massage and it seems to be down to a partial pairing. I’ve deleted the device, rebooted the hub and repaired, and its still the same.
I’m wondering if a change in hub firmware is causing a problem? I’ve tried different device handlers and the fibaro fails to respond.
Has anyone come accross anything like this, or have any suggestions? This is a big show stopper for me.
Thanks
