My Door Check piston is announcing twice.
When I tell Alexa “Door Check” (or if I hit TEST), this piston should run, check all door contacts, set the LEDs on my Homeseer 200+, and announce if any doors are open.
If I press Test, it works perfectly. If I say “Alexa, Door Check”, she makes the announcement twice. It’s almost as if the piston is activated by the switch turning on AND off.
Logging set to Minimum
This shows that the switch turning On and Off is executing the piston!
5/17/2021, 11:46:44 PM +120ms
+1ms ╔Received event [Door Check].switch = off with a delay of 628ms, canQueue: false, calledMyself: true
+5ms ║╔Execution stage started
+125ms ║║ All Doors are CLOSED at 11:46 P.M. on Mon, 5/17/2021
+168ms ║╚Execution stage complete. (164ms)
+171ms ╚Event processed successfully (169ms)
5/17/2021, 11:46:43 PM +420ms
+4ms ╔Received event [Door Check].switch = on with a delay of 84ms, canQueue: true, calledMyself: false
+28ms ║╔Execution stage started
+620ms ║║ All Doors are CLOSED at 11:46 P.M. on Mon, 5/17/2021
+644ms ║╚Execution stage complete. (616ms)
+647ms ╚Event processed successfully (644ms)
Logging set to Full
5/17/2021, 11:39:14 PM +522ms
+1ms ╔Received event [Door Check].switch = off with a delay of 651ms, canQueue: false, calledMyself: true
+8ms ║RunTime initialize > 7 LockT > 0ms > rtDT > 5ms > pistonT > 2ms (first state access 2 2 5)
+13ms ║Runtime (20552 bytes) successfully initialized in 5ms (v0.3.113.20210510_HE)
+14ms ║╔Execution stage started
+20ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+22ms ║║Cancelling condition #2’s schedules…
+23ms ║║Condition #2 evaluated false (5ms)
+24ms ║║Cancelling condition #1’s schedules…
+25ms ║║Condition group #1 evaluated false (state changed) (7ms)
+33ms ║║Comparison (enum) closed is (string) open = false (1ms)
+34ms ║║Comparison (enum) closed is (string) open = false (1ms)
+36ms ║║Comparison (enum) closed is (string) open = false (0ms)
+37ms ║║Comparison (enum) closed is (string) open = false (1ms)
+39ms ║║Comparison (enum) closed is (string) open = false (0ms)
+41ms ║║Comparison (enum) closed is (string) open = false (1ms)
+42ms ║║Comparison (enum) closed is (string) open = false (0ms)
+45ms ║║Condition #8 evaluated false (18ms)
+46ms ║║Condition group #7 evaluated false (state did not change) (20ms)
+48ms ║║Cancelling statement #52’s schedules…
+58ms ║║Calculating (dynamic)null == (integer)1 >> (boolean)false
+68ms ║║Calculating (string) All Doors are CLOSED at + (string)11:39 P.M. >> (string) All Doors are CLOSED at 11:39 P.M.
+69ms ║║Calculating (string) All Doors are CLOSED at 11:39 P.M. + (string) on >> (string) All Doors are CLOSED at 11:39 P.M. on
+70ms ║║Calculating (string) All Doors are CLOSED at 11:39 P.M. on + (string)Mon, 5/17/2021 >> (string) All Doors are CLOSED at 11:39 P.M. on Mon, 5/17/2021
+72ms ║║Calculating (string) All Doors are CLOSED at 11:39 P.M. on Mon, 5/17/2021 + (string) >> (string) All Doors are CLOSED at 11:39 P.M. on Mon, 5/17/2021
+74ms ║║Calculating (string) The + (string) >> (string) The
+76ms ║║Calculating (string) The + (string) >> (string) The
+77ms ║║Calculating (string) The + (string) >> (string) The
+78ms ║║Calculating (string) The + (string) >> (string) The
+80ms ║║Calculating (string) The + (string)are >> (string) The are
+81ms ║║Calculating (string) The are + (string) >> (string) The are
+82ms ║║Calculating (string) The are + (string) OPEN >> (string) The are OPEN
+83ms ║║Calculating (string) The are OPEN + (string) at >> (string) The are OPEN at
+85ms ║║Calculating (string) The are OPEN at + (string)11:39 P.M. >> (string) The are OPEN at 11:39 P.M.
+86ms ║║Calculating (string) The are OPEN at 11:39 P.M. + (string) on >> (string) The are OPEN at 11:39 P.M. on
+88ms ║║Calculating (string) The are OPEN at 11:39 P.M. on + (string)Mon, 5/17/2021 >> (string) The are OPEN at 11:39 P.M. on Mon, 5/17/2021
+89ms ║║Calculating (string) The are OPEN at 11:39 P.M. on Mon, 5/17/2021 + (string) >> (string) The are OPEN at 11:39 P.M. on Mon, 5/17/2021
+90ms ║║Calculating (integer)0 == (integer)0 >> (boolean)true
+94ms ║║Executed virtual command setVariable (2ms)
+109ms ║║Executed virtual command setState (0ms)
+112ms ║║ All Doors are CLOSED at 11:39 P.M. on Mon, 5/17/2021
+114ms ║║Executed virtual command log (2ms)
+229ms ║║Calculating (dynamic)null == (integer)1 >> (boolean)false
+232ms ║║Calculating (string)The + (string) >> (string)The
+233ms ║║Calculating (string)The + (string) >> (string)The
+234ms ║║Calculating (string)The + (string)are >> (string)The are
+235ms ║║Calculating (string)The are + (string) open. >> (string)The are open.
+236ms ║║Calculating (integer)0 == (integer)0 >> (boolean)true
+289ms ║║Executed virtual command setVariable (50ms)
+295ms ║║Executed virtual command setVariable (2ms)
+301ms ║║Executed virtual command setVariable (1ms)
