Smartthings switch is on garage door. Trying to get switch to turn on at sunset if sensor is open and then if I open garage door after sunset want switch on 15 min after contact switch is opened
Cant figure out y this will not work
Gord
WCmore
I am going to guess that lines 27 & 40 should read:
IF variable "@contact_open_true" is "true"
Gord
I didn’t realize it but the variable was global so changed to local
Does not matter if the contact changes to open or closed
Under Quick Facts “piston state” stays false
Within the piston under
defind
boolean contact_sensor; /* true */ this does not change either
Whats the difference
Gord
ok works for the most part but when contact sensor opens between sunrise and 11:59 variable does not change to true
Gord
Still having problems with this piston
Even though the variable is false switch 8 still turns on at sunset
Line 31 do i have to make that a trigger rather than a condition
E_Sch
If you have not figured this out, you should post current piston and full logs for when it runs
