Got it. Initial state was lanai lights on, keezer light on. Final state was lanai lights on, keezer light off.
12/6/2018, 10:32:11 AM +623ms
+1ms ╔Received event [Walkway Motion].motion = inactive with a delay of 662ms
+7884ms ║RunTime Analysis CS > 24ms > PS > 7798ms > PE > 62ms > CE
+7885ms ║Piston waited at a semaphore for 7765ms
+7888ms ║Runtime (44162 bytes) successfully initialized in 7798ms (v0.3.108.20180906) (7886ms)
+7889ms ║╔Execution stage started
+7898ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+7900ms ║║Cancelling condition #8’s schedules…
+7901ms ║║Condition #8 evaluated false (7ms)
+7902ms ║║Cancelling condition #1’s schedules…
+7904ms ║║Condition group #1 evaluated false (state changed) (9ms)
+7906ms ║╚Execution stage complete. (18ms)
+7907ms ╚Event processed successfully (7908ms)
12/6/2018, 10:32:09 AM +128ms
+1ms ╔Received event [Home].time = 1544110329741 with a delay of -614ms
+270ms ║RunTime Analysis CS > 74ms > PS > 134ms > PE > 63ms > CE
+273ms ║Runtime (44083 bytes) successfully initialized in 134ms (v0.3.108.20180906) (272ms)
+274ms ║╔Execution stage started
+350ms ║║Restoring attribute ‘switch’ to value ‘off’ using command off()
+367ms ║║Executed physical command [Keezer Light].off() (15ms)
+368ms ║║Executed virtual command [Keezer Light].loadStateLocally (25ms)
+376ms ║║Restoring attribute ‘switch’ to value ‘on’ using command on()
+2894ms ║║Executed physical command [Lanai Lights].on() (2516ms)
+2896ms ║║Executed virtual command [Lanai Lights].loadStateLocally (2525ms)
+2899ms ║╚Execution stage complete. (2625ms)
+2901ms ╚Event processed successfully (2901ms)
12/6/2018, 10:32:02 AM +119ms
+1ms ╔Received event [Home].time = 1544110318214 with a delay of 3905ms
+127ms ║RunTime Analysis CS > 27ms > PS > 41ms > PE > 59ms > CE
+130ms ║Runtime (44081 bytes) successfully initialized in 41ms (v0.3.108.20180906) (128ms)
+190ms ║║Executed physical command [Hallway Light].off() (34ms)
+191ms ║║Executed [Hallway Light].off (37ms)
+196ms ║╚Execution stage complete. (65ms)
+198ms ║Setting up scheduled job for Thu, Dec 6 2018 @ 10:32:09 AM EST (in 7.425s)
+207ms ╚Event processed successfully (207ms)
12/6/2018, 10:31:53 AM +11ms
+0ms ╔Received event [Walkway Motion].motion = active with a delay of 662ms
+106ms ║RunTime Analysis CS > 21ms > PS > 29ms > PE > 57ms > CE
+109ms ║Runtime (44089 bytes) successfully initialized in 29ms (v0.3.108.20180906) (108ms)
+111ms ║╔Execution stage started
+121ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+123ms ║║Cancelling condition #8’s schedules…
+124ms ║║Condition #8 evaluated true (8ms)
+125ms ║║Cancelling condition #1’s schedules…
+126ms ║║Condition group #1 evaluated true (state changed) (10ms)
+146ms ║║Comparison (time) 37913140 is_between (datetime) 1544098080000 … (datetime) 1544135700000 = true (9ms)
+148ms ║║Time restriction check passed
+150ms ║║Condition #19 evaluated true (21ms)
+151ms ║║Condition group #18 evaluated true (state did not change) (22ms)
+164ms ║║Comparison (enum) off is (string) off = true (2ms)
+166ms ║║Condition #31 evaluated true (11ms)
+167ms ║║Condition group #30 evaluated true (state did not change) (13ms)
+170ms ║║Cancelling statement #24’s schedules…
+194ms ║║Executed physical command [Hallway Light].on() (21ms)
+196ms ║║Executed [Hallway Light].on (23ms)
+200ms ║║Executed virtual command [Hallway Light].wait (1ms)
+202ms ║║Requesting a wake up for Thu, Dec 6 2018 @ 10:31:58 AM EST (in 5.0s)
+209ms ║║Cancelling statement #10’s schedules…
+227ms ║║Executed virtual command [Keezer Light].saveStateLocally (1ms)
+229ms ║║Executed virtual command [Lanai Lights].saveStateLocally (1ms)
+238ms ║║Calculating (string) Last trigger on + (string) Thu, Dec 6 2018 @ 10:31:53 AM EST >> (string) Last trigger on Thu, Dec 6 2018 @ 10:31:53 AM EST
+242ms ║║Calculating (string) Last trigger on Thu, Dec 6 2018 @ 10:31:53 AM EST + (string) . >> (string) Last trigger on Thu, Dec 6 2018 @ 10:31:53 AM EST.
+245ms ║║Executed virtual command [Keezer Light, Lanai Lights].setState (1ms)
+250ms ║║Executed virtual command [Keezer Light, Lanai Lights].wait (0ms)
+251ms ║║Waiting for 2000ms
+2256ms ║║Cancelling statement #3’s schedules…
+2275ms ║║Executed physical command [Keezer Light].off() (12ms)
+2276ms ║║Executed virtual command [Keezer Light].toggle (16ms)
+2382ms ║║Executed physical command [Lanai Lights].off() (101ms)
+2383ms ║║Executed virtual command [Lanai Lights].toggle (105ms)
+2388ms ║║Executed virtual command [Keezer Light, Lanai Lights].wait (1ms)
+2389ms ║║Waiting for 1000ms
+3399ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+3403ms ║║Executed virtual command [Keezer Light, Lanai Lights].setVariable (2ms)
+3410ms ║║Comparison (integer) 1 is_equal_to (integer) 4 = false (2ms)
+3412ms ║║Cancelling condition #7’s schedules…
+3413ms ║║Condition #7 evaluated false (8ms)
+3415ms ║║Cancelling condition #2’s schedules…
+3416ms ║║Condition group #2 evaluated false (state changed) (11ms)
+3419ms ║║Cancelling statement #3’s schedules…
+3436ms ║║Executed physical command [Keezer Light].off() (11ms)
+3437ms ║║Executed virtual command [Keezer Light].toggle (15ms)
+3556ms ║║Executed physical command [Lanai Lights].on() (115ms)
+3557ms ║║Executed virtual command [Lanai Lights].toggle (119ms)
+3562ms ║║Executed virtual command [Keezer Light, Lanai Lights].wait (1ms)
+3563ms ║║Waiting for 1000ms
+4571ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+4575ms ║║Executed virtual command [Keezer Light, Lanai Lights].setVariable (2ms)
+4582ms ║║Comparison (integer) 2 is_equal_to (integer) 4 = false (2ms)
+4584ms ║║Condition #7 evaluated false (7ms)
+4585ms ║║Condition group #2 evaluated false (state did not change) (8ms)
+4588ms ║║Cancelling statement #3’s schedules…
+4606ms ║║Executed physical command [Keezer Light].off() (10ms)
+4607ms ║║Executed virtual command [Keezer Light].toggle (15ms)
+4623ms ║║Executed physical command [Lanai Lights].off() (11ms)
+4625ms ║║Executed virtual command [Lanai Lights].toggle (16ms)
+4629ms ║║Executed virtual command [Keezer Light, Lanai Lights].wait (1ms)
+4630ms ║║Waiting for 1000ms
+5638ms ║║Calculating (integer) 2 + (integer) 1 >> (integer) 3
+5642ms ║║Executed virtual command [Keezer Light, Lanai Lights].setVariable (2ms)
+5649ms ║║Comparison (integer) 3 is_equal_to (integer) 4 = false (1ms)
+5651ms ║║Condition #7 evaluated false (6ms)
+5652ms ║║Condition group #2 evaluated false (state did not change) (8ms)
+5655ms ║║Cancelling statement #3’s schedules…
+5671ms ║║Executed physical command [Keezer Light].off() (10ms)
+5673ms ║║Executed virtual command [Keezer Light].toggle (14ms)
+5688ms ║║Executed physical command [Lanai Lights].on() (11ms)
+5689ms ║║Executed virtual command [Lanai Lights].toggle (15ms)
+5694ms ║║Executed virtual command [Keezer Light, Lanai Lights].wait (1ms)
+5695ms ║║Waiting for 1000ms
+6703ms ║║Calculating (integer) 3 + (integer) 1 >> (integer) 4
+6707ms ║║Executed virtual command [Keezer Light, Lanai Lights].setVariable (1ms)
+6714ms ║║Comparison (integer) 4 is_equal_to (integer) 4 = true (2ms)
+6715ms ║║Cancelling condition #7’s schedules…
+6717ms ║║Condition #7 evaluated true (7ms)
+6718ms ║║Cancelling condition #2’s schedules…
+6719ms ║║Condition group #2 evaluated true (state changed) (11ms)
+6722ms ║║Cancelling statement #12’s schedules…
+6728ms ║║Executed virtual command [Keezer Light, Lanai Lights].wait (1ms)
+6730ms ║║Requesting a wake up for Thu, Dec 6 2018 @ 10:32:09 AM EST (in 10.0s)
+6735ms ║╚Execution stage complete. (6625ms)
+6737ms ║Setting up scheduled job for Thu, Dec 6 2018 @ 10:31:58 AM EST (in 1s), with 1 more job pending
+6746ms ╚Event processed successfully (6746ms)
