Can't resume a paused piston or save when creating a new one
I can’t resume paused pistons or save a new piston when creating one.
I just want webcore to work again lol
I was trying to replicate pistons within ST automation, so I had paused them all. After failing to get the automation to behave how I wanted, I deleted the native routines in ST and tried to resume them in webcore. After multiple attempts to resume the pistons, I tried recreating the pistons. In both circumstances, it just hangs and never resumes or saves.
**4) Post a Green Snapshot
Doesn’t matter which piston I try this with.
No logs as I can’t run the piston.
Clean up and rebuild data cache in your instance of webcore under settings
I should also ask how you paused all your pistons. Did you pause them individually on the webcore dashboard or did you disabled your instance of webcore in the ST app? If you disabled in the St app, you would need to login to IDE, go to locations > smartapps, find your pistons and click the paused icon on each to make them run again.
I’ve cleared data multiple times, and I paused each piston individually within webcore.
I’ll try clearing data again for s&gs.
Did a screen recording to show what is happening.
