For the record, I rewrote this piston and it’s working fine, but I was kinda disappointed that this manner didn’t work. I was just curious if this was normal behavior for the code.
This piston checks for open doors and outdoor lights that are on. The piston should state if doors are open (save devices to list) OR lights are on (save devices to list). However, it only works with an AND.
If doors are open, the piston will create a list of open doors. If outdoor lights are on, it will create a list of outdoor lights that are on.
The piston only works with AND, which could presumably cause a problem if all doors are closed but an outdoor light is on. Basically, if a door is open, it skips over the second OR line.
If anyone’s curious, here’s the new version:
