I’m trying to update the smarts of our pantry light switch (a Zoos S2 Zen26 on/off) and it’s not working. I’m sure there’s a similar example around here somewhere but I’ve been unable to find it. I believe the problem is that I’m not able to capture the events that I’m using as triggers, which are either a single or double tap on the up paddle of the switch. All other aspects of the piston work.
The part of the piston that is not working should work like:
- IF switch button for single tap OR switch button for double tap is pressed THEN set variable to true
- I then use that variable to add an additional 25 minute delay on turning the switch off
According to the logs, it looks like the variable is never getting set to true. The Zoos support article says that a single tap on the up paddle is button 1 and a double tap is button 3. When I set up the button press trigger it offers me buttons #1-32, but the button values in the log are “up” and “up_2x”
Oddly (to me), if I single or double-tap the switch, then the light just never turns off, so the event is somehow causing it to skip the initial 5-minute turn off timer I have set, but not use the second 25 minute timer to turn off.
11/16/2020, 11:41:51 PM +81ms
+1ms ╔Received event [Pantry Light].button = up_2x with a delay of 39ms
+371ms ║RunTime Analysis CS > 15ms > PS > 338ms > PE > 18ms > CE
+374ms ║Runtime (40927 bytes) successfully initialized in 338ms (v0.3.110.20191009) (372ms)
+375ms ║╔Execution stage started
+386ms ║║Condition #2 evaluated false (7ms)
+387ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+404ms ║║Condition #6 evaluated false (13ms)
+405ms ║║Condition group #5 evaluated false (state did not change) (15ms)
+410ms ║║Comparison (enum) up_2x gets (string) pushed = false (1ms)
+411ms ║║Condition #23 evaluated false (4ms)
+412ms ║║Condition group #22 evaluated false (state did not change) (5ms)
+423ms ║║Condition #10 evaluated false (8ms)
+424ms ║║Condition group #9 evaluated false (state did not change) (10ms)
+426ms ║╚Execution stage complete. (50ms)
+427ms ╚Event processed successfully (426ms)
11/16/2020, 11:35:27 PM +92ms
+1ms ╔Received event [Home].time = 1605594928042 with a delay of -950ms
+158ms ║RunTime Analysis CS > 39ms > PS > 97ms > PE > 21ms > CE
+161ms ║Runtime (40925 bytes) successfully initialized in 97ms (v0.3.110.20191009) (159ms)
+162ms ║╔Execution stage started
+163ms ║╚Execution stage complete. (1ms)
+165ms ╚Event processed successfully (164ms)
11/16/2020, 11:31:18 PM +5ms
+1ms ╔Received event [Pantry Light].button = up with a delay of 40ms
+93ms ║RunTime Analysis CS > 16ms > PS > 61ms > PE > 17ms > CE
+95ms ║Runtime (40803 bytes) successfully initialized in 61ms (v0.3.110.20191009) (94ms)
+107ms ║║Condition #2 evaluated false (7ms)
+108ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+116ms ║║Condition #6 evaluated false (6ms)
+117ms ║║Condition group #5 evaluated false (state did not change) (7ms)
+123ms ║║Comparison (enum) up gets (string) pushed = false (0ms)
+124ms ║║Condition #23 evaluated false (4ms)
+125ms ║║Condition group #22 evaluated false (state did not change) (6ms)
+134ms ║║Cancelling condition #10’s schedules…
+135ms ║║Condition #10 evaluated false (8ms)
+136ms ║║Cancelling condition #9’s schedules…
+137ms ║║Condition group #9 evaluated false (state changed) (10ms)
+139ms ║╚Execution stage complete. (43ms)
+140ms ╚Event processed successfully (140ms)
11/16/2020, 11:30:27 PM +897ms
+2ms ╔Received event [Pantry Light].switch = on with a delay of 39ms
+92ms ║RunTime Analysis CS > 20ms > PS > 56ms > PE > 16ms > CE
+95ms ║Runtime (40807 bytes) successfully initialized in 56ms (v0.3.110.20191009) (92ms)
+107ms ║║Cancelling condition #2’s schedules…
+108ms ║║Condition #2 evaluated false (8ms)
+109ms ║║Cancelling condition #1’s schedules…
+110ms ║║Condition group #1 evaluated false (state changed) (10ms)
+118ms ║║Condition #6 evaluated false (6ms)
+119ms ║║Condition group #5 evaluated false (state did not change) (7ms)
+128ms ║║Condition #23 evaluated false (7ms)
+129ms ║║Condition group #22 evaluated false (state did not change) (8ms)
+134ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+135ms ║║Cancelling condition #10’s schedules…
+136ms ║║Condition #10 evaluated true (5ms)
+137ms ║║Cancelling condition #9’s schedules…
+138ms ║║Condition group #9 evaluated true (state changed) (7ms)
+140ms ║║Cancelling statement #16’s schedules…
+143ms ║║Executed virtual command [Pantry Light].wait (0ms)
+145ms ║║Requesting a wake up for Mon, Nov 16 2020 @ 11:35:28 PM MST (in 300.0s)
+148ms ║╚Execution stage complete. (52ms)
+150ms ║Setting up scheduled job for Mon, Nov 16 2020 @ 11:35:28 PM MST (in 299.996s)
+156ms ╚Event processed successfully (156ms)
11/16/2020, 11:30:27 PM +120ms
+1ms ╔Received event [Pantry Door].contact = open with a delay of 55ms
+91ms ║RunTime Analysis CS > 17ms > PS > 58ms > PE > 15ms > CE
+93ms ║Runtime (40813 bytes) successfully initialized in 58ms (v0.3.110.20191009) (91ms)
+101ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+103ms ║║Cancelling condition #2’s schedules…
+103ms ║║Condition #2 evaluated true (5ms)
+104ms ║║Cancelling condition #1’s schedules…
+105ms ║║Condition group #1 evaluated true (state changed) (7ms)
+107ms ║║Cancelling statement #3’s schedules…
+254ms ║║Executed physical command [Pantry Light].on() (143ms)
+255ms ║║Executed [Pantry Light].on (144ms)
+260ms ║║Executed virtual command [Pantry Light].setVariable (2ms)
+265ms ║║Comparison (enum) open changes_to (string) closed = false (1ms)
+267ms ║║Condition #6 evaluated false (4ms)
+267ms ║║Condition group #5 evaluated false (state did not change) (5ms)
+276ms ║║Condition #23 evaluated false (6ms)
+277ms ║║Condition group #22 evaluated false (state did not change) (8ms)
+285ms ║║Condition #10 evaluated false (6ms)
+286ms ║║Condition group #9 evaluated false (state did not change) (7ms)
+288ms ║╚Execution stage complete. (194ms)
+289ms ╚Event processed successfully (289ms)
