I want my piston to set the ceiling fan speed based on the current indoor temperature when the fan is initially turned on. The log shows the piston runs fine, but then the fan speed always reverts back to the speed setting prior to the piston running.
Have ceiling fan automatically go to proper speed setting associated with indoor temperature when initially turned on.
Ceiling fan speed adjusts to proper speed via piston but then ends on the speed setting prior to the piston running (can see this happening in smartthings ide log)
**5) Attach any logs (From ST IDE and by turning logging level to Fu
