Hi. I’d like to make a piston that only changes a global variable when a switch is on or off.
I can create a piston where I set the IF for the switch state change, but then I want to create a statement for the THEN action and I cannot select a variable directly from there. How do I do that?
Thanks,
Rodrigo
