With the double quotes. The piston Groovy code calls ‘tokenize()’ to split a string into a list on the comma. If you do it without the quotes you get Groovy errors in the logs complaining about attempting it on integers.
Starting level 48, followed by 75, 17, 51, 50, 14, 25 and 49.
Logs
13/07/2020, 07:46:44 +459ms
+2ms ╔Received event [Shed Virtual Temperature Test].level = 49 with a delay of 68ms
+55ms ║RunTime Analysis CS > 17ms > PS > 26ms > PE > 11ms > CE
+57ms ║Runtime (36382 bytes) successfully initialized in 26ms (v0.3.110.20191009) (55ms)
+58ms ║╔Execution stage started
+66ms ║║Comparison (integer) 49 changes_away_from_any_of (string) 25,50,75 = true (1ms)
+67ms ║║Cancelling condition #2’s schedules…
+68ms ║║Condition #2 evaluated true (6ms)
+69ms ║║Cancelling condition #1’s schedules…
+70ms ║║Condition group #1 evaluated true (state changed) (8ms)
+71ms ║╚Execution stage complete. (14ms)
+72ms ╚Event processed successfully (72ms)
13/07/2020, 07:37:52 +565ms
+2ms ╔Received event [Shed Virtual Temperature Test].level = 25 with a delay of 69ms
+51ms ║RunTime Analysis CS > 17ms > PS > 24ms > PE > 9ms > CE
+53ms ║Runtime (36376 bytes) successfully initialized in 24ms (v0.3.110.20191009) (50ms)
+53ms ║╔Execution stage started
+61ms ║║Comparison (integer) 25 changes_away_from_any_of (string) 25,50,75 = false (3ms)
+62ms ║║Cancelling condition #2’s schedules…
+63ms ║║Condition #2 evaluated false (5ms)
+63ms ║║Cancelling condition #1’s schedules…
+64ms ║║Condition group #1 evaluated false (state changed) (8ms)
+66ms ║╚Execution stage complete. (13ms)
+67ms ╚Event processed successfully (66ms)
13/07/2020, 07:37:47 +65ms
+2ms ╔Received event [Shed Virtual Temperature Test].level = 14 with a delay of 75ms
+60ms ║RunTime Analysis CS > 22ms > PS > 27ms > PE > 11ms > CE
+63ms ║Runtime (36382 bytes) successfully initialized in 27ms (v0.3.110.20191009) (59ms)
+63ms ║╔Execution stage started
+72ms ║║Comparison (integer) 14 changes_away_from_any_of (string) 25,50,75 = true (2ms)
+73ms ║║Cancelling condition #2’s schedules…
+74ms ║║Condition #2 evaluated true (7ms)
+75ms ║║Cancelling condition #1’s schedules…
+76ms ║║Condition group #1 evaluated true (state changed) (9ms)
+78ms ║╚Execution stage complete. (15ms)
+79ms ╚Event processed successfully (79ms)
13/07/2020, 07:37:43 +133ms
+1ms ╔Received event [Shed Virtual Temperature Test].level = 50 with a delay of 68ms
+51ms ║RunTime Analysis CS > 18ms > PS > 24ms > PE > 8ms > CE
+53ms ║Runtime (36381 bytes) successfully initialized in 24ms (v0.3.110.20191009) (51ms)
+62ms ║║Comparison (integer) 50 changes_away_from_any_of (string) 25,50,75 = false (3ms)
+63ms ║║Condition #2 evaluated false (6ms)
+64ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+66ms ║╚Execution stage complete. (12ms)
13/07/2020, 07:37:34 +571ms
+2ms ╔Received event [Shed Virtual Temperature Test].level = 51 with a delay of 68ms
+59ms ║RunTime Analysis CS > 20ms > PS > 28ms > PE > 10ms > CE
+61ms ║Runtime (36377 bytes) successfully initialized in 28ms (v0.3.110.20191009) (59ms)
+62ms ║╔Execution stage started
+71ms ║║Comparison (integer) 51 changes_away_from_any_of (string) 25,50,75 = false (3ms)
+73ms ║║Condition #2 evaluated false (7ms)
+75ms ║║Condition group #1 evaluated false (state changed) (9ms)
+77ms ║╚Execution stage complete. (15ms)
+78ms ╚Event processed successfully (78ms)
13/07/2020, 07:37:20 +833ms
+2ms ╔Received event [Shed Virtual Temperature Test].level = 17 with a delay of 69ms
+56ms ║RunTime Analysis CS > 19ms > PS > 26ms > PE > 11ms > CE
+58ms ║Runtime (36382 bytes) successfully initialized in 26ms (v0.3.110.20191009) (56ms)
+59ms ║╔Execution stage started
+69ms ║║Comparison (integer) 17 changes_away_from_any_of (string) 25,50,75 = true (3ms)
+71ms ║║Cancelling condition #2’s schedules…
+72ms ║║Condition #2 evaluated true (8ms)
+73ms ║║Cancelling condition #1’s schedules…
+74ms ║║Condition group #1 evaluated true (state changed) (10ms)
+76ms ║╚Execution stage complete. (17ms)
+78ms ╚Event processed successfully (77ms)
13/07/2020, 07:37:10 +373ms
+1ms ╔Received event [Shed Virtual Temperature Test].level = 75 with a delay of 72ms
+53ms ║RunTime Analysis CS > 17ms > PS > 23ms > PE > 12ms > CE
+55ms ║Runtime (36356 bytes) successfully initialized in 23ms (v0.3.110.20191009) (53ms)
+56ms ║╔Execution stage started
+65ms ║║Comparison (integer) 75 changes_away_from_any_of (string) 25,50,75 = false (2ms)
+66ms ║║Condition #2 evaluated false (6ms)
+67ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+68ms ║╚Execution stage complete. (12ms)
+69ms ╚Event processed successfully (69ms)
