Check $device's contact status but always showing any of in the front
I have a loop for a collection list of devices. In the loop, I want to check $device’s contact status. I saw examples people made but got no idea how could I do the same. I tried [$device : contact] is “open” and it seems not working. I tried to use {$device}'s conact…, but always have “any of” in front of it.
If I compare [$device : contact] to a real contact’s status, it works. I want to actually do {$device}'s contact is open. Currently it’s showing any of {$device}'s contact is open. I guess it should work but just don’t know why I can’t remove any of in the front.
Should have statement as {$device}'s contact is open not any of {$device}'s contact is open.
**4) Post a Green Snapshot of the piston!58%20AM
Tried If any of {[$device:contact]}'s contact is open ?
If I remember correctly, whether you saw any of / all of depended on where you looked.
Regardless of that I don’t see a problem with any of being displayed. $device may be a system variable but it is still a device variable and device variables can contain multiple devices. The UI doesn’t know what the contents will be at runtime.
