Then a new variable is created with datetime type, the default value will be Invalid Date.
There should be a function to check if the datetime type variable is invalid.
The IsEmpty() function can work on dynamic type variable but not datetime variable.
To make things worse when datetime variable with Invalid Date, the variable will act as if it is assigned with the current datetime value at run time.
N/A
N/A
