I have a central heating system reliant on DS18b20 sensors connected through a fibaro UBS. Everything is controlled through webcore.
If a sensor (for whatever reason) becomes unavailable, or stops updating, or reads an odd temperature, I need to flag a fault.
Need a way of checking the sensor is working. Initially the potential solutions seemed to suggest pistons checking on the ACTIVE states and going from there. But…
…it seems it’s possible for the sensors to still show as ACTIVE/ONLINE etc even if no changes have been received for anything between seconds or hours. So I’m struggling to find a way of determining whether it’s ok, or whether (I suspect) the temp has remained unchanged for a while.
(UPLOAD YOUR IMAGE HERE)
