No matter what, if the door is closed the chime will activate
The chime should activate it the front door has not been opened or closed in 2 minutes, and the door is shut
The chime activates if the door was just opened or closed within 2 minutes.
Basically, it’s a battery operated chime and it goes off way to many times, trying to mitigate that. The batteries are NOT cheap
