Clear all values of list variable
Quick and kinda noob question here.
How can I completely clear a list variable so there’s nothing left stored?
I have a set variable command looping where the end of loop is varying from run to run (will sometime set values for 0 to 15, and some other time 0 to 11.) I don’t want values stored in position 12 to 15 to stick when they don’t get overridden.
Thanks,
@ady624 you mate sure have a trick up your sleeve?
I have not seen a way to remove keys, one approach I’ve used is to manually maintain a length property on the list (could also be a top-level variable to if your piston only has one array to maintain.
  • To push an item assign the value to myArray at index int(myArray[length]) then assign the value int(myArray[length]) + 1 to myArray at index length
  • To iterate use a for loop from zero to int(myArray[length]) - 1 (be sure to use an integer variable rather than $index which does not work with zero)
  • To reset the array set myArray at index length to 0
Thanks, I’ll try this tomorrow and report back.
Do you think this should be added to low priority feature suggestion, in the form of a new command in location? Since I’m not very used to coding I always have a hard time to judge whether I’m erring or not.
