My piston was working great until a few days ago. The color of a bulb no longer changes color because the dynamic info is “stuck” at 32 degrees and the associated hex color.
The bulb color should change based on the temperature reported in the Get request. The data used has not seemed to change https://swd.weatherflow.com/swd/rest/observations/station/8616?token=5894bcfa-a5fc-4188-8637-77dff56426bb
It’s not using the reported temperature from the GET request and is reverting to only 32 degrees. Not sure if it’s a coincidence as I recently updated my webcore smart app.
(upload://f03B65VPQ38BbkHS5zQijdJRiag.png)
2/8/2021, 1:33:01 PM +366ms
+0ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 1ms
+71ms ║RunTime Analysis CS > 16ms > PS > 6ms > PE > 49ms > CE
+74ms ║Runtime (46167 bytes) successfully initialized in 6ms (v0.3.113.20210203) (73ms)
+75ms ║╔Execution stage started
+89ms ║║Calculating (decimal) 32.0 , (decimal) 0.0 >> (decimal) 32.0
+93ms ║║Executed virtual command setVariable (2ms)
+137ms ║║Calculating (dynamic) 32.0 <= (integer) 110 >> (boolean) true
+143ms ║║Calculating (dynamic) 32.0 <= (integer) 100 >> (boolean) true
+148ms ║║Calculating (dynamic) 32.0 <= (integer) 95 >> (boolean) true
+153ms ║║Calculating (dynamic) 32.0 <= (integer) 90 >> (boolean) true
+159ms ║║Calculating (dynamic) 32.0 <= (integer) 85 >> (boolean) true
+164ms ║║Calculating (dynamic) 32.0 <= (integer) 80 >> (boolean) true
+169ms ║║Calculating (dynamic) 32.0 <= (integer) 75 >> (boolean) true
+174ms ║║Calculating (dynamic) 32.0 <= (integer) 70 >> (boolean) true
+179ms ║║Calculating (dynamic) 32.0 <= (integer) 65 >> (boolean) true
+184ms ║║Calculating (dynamic) 32.0 <= (integer) 60 >> (boolean) true
+188ms ║║Calculating (dynamic) 32.0 <= (integer) 55 >> (boolean) true
+193ms ║║Calculating (dynamic) 32.0 <= (integer) 50 >> (boolean) true
+197ms ║║Calculating (dynamic) 32.0 <= (integer) 45 >> (boolean) true
+202ms ║║Calculating (dynamic) 32.0 <= (decimal) 40.0 >> (boolean) true
+206ms ║║Calculating (dynamic) 32.0 <= (decimal) 32.0 >> (boolean) true
+210ms ║║Calculating (dynamic) 32.0 <= (decimal) 15.0 >> (boolean) false
+214ms ║║Calculating (dynamic) 32.0 <= (decimal) 0.0 >> (boolean) false
+217ms ║║Calculating (decimal) 0.0 - (decimal) 5.0 >> (decimal) -5.0
+220ms ║║Calculating (dynamic) 32.0 <= (decimal) -5.0 >> (boolean) false
+225ms ║║Executed virtual command setVariable (3ms)
+227ms ║║Cancelling statement #23’s schedules…
+238ms ║║Executed physical command [Weather Lamp].setColor([[hex: #4242ff, hue:67, saturation:100, level:63]]) (5ms)
+238ms ║║Executed [Weather Lamp].setColor (8ms)
+241ms ║╚Execution stage complete. (166ms)
+242ms ║Setting up scheduled job for Mon, Feb 8 2021 @ 1:38:02 PM CST (in 300s)
+252ms ╚Event processed successfully (252ms)
