I have written a piston to cycle through hues on a couple of LED strips. I have created a virtual switch in Smarttings that triggers the cycle to turn off and on. What I’d like to do is have this cycle turn off whenever something else changes the hue of the strips (e.g. a scene or manually changing the color in smartthings, etc.)
I’ve created a variable that changes the hue and then I created a conditional statement that if the hue of the light is different than the variable to turn the virtual switch off, which should then exit the while loop.
The comparison statement is getting “false positives” so to speak. So I turn on the switch to start the cycle, but it then turns off because the conditional statement is evaluated as true.
11/5/2020, 9:01:41 PM +56ms
+1ms ╔Received event [Home].time = 1604635299593 with a delay of 1462ms
+105ms ║RunTime Analysis CS > 20ms > PS > 57ms > PE > 29ms > CE
+108ms ║Runtime (42097 bytes) successfully initialized in 57ms (v0.3.110.20191009) (106ms)
+142ms ║║Comparison (integer) 9 is_equal_to (integer) 360 = false (1ms)
+143ms ║║Condition #20 evaluated false (5ms)
+144ms ║║Condition group #19 evaluated false (state did not change) (6ms)
+160ms ║║Comparison (integer) 7 is_different_than (integer) 9 = true (1ms)
+161ms ║║Condition #34 evaluated true (14ms)
+162ms ║║Condition group #33 evaluated true (state did not change) (15ms)
+165ms ║║Cancelling statement #35's schedules...
+172ms ║║Skipped execution of physical command [Living Room color loop].off([]) because it would make no change to the device. (3ms)
+173ms ║║Executed [Living Room color loop].off (5ms)
+181ms ║║Comparison (enum) off is (string) on = false (1ms)
+183ms ║║Cancelling condition #32's schedules...
+184ms ║║Condition #32 evaluated false (9ms)
+186ms ║║Cancelling condition #14's schedules...
+187ms ║║Condition group #14 evaluated false (state changed) (12ms)
+192ms ║╚Execution stage complete. (83ms)
+193ms ╚Event processed successfully (193ms)
11/5/2020, 9:01:30 PM +854ms
+1ms ╔Received event [Living Room color loop].switch = off with a delay of 36ms
+8871ms ║RunTime Analysis CS > 17ms > PS > 8814ms > PE > 40ms > CE
+8873ms ║Piston waited at a semaphore for 8766ms
+8875ms ║Runtime (42176 bytes) successfully initialized in 8814ms (v0.3.110.20191009) (8873ms)
+8876ms ║╔Execution stage started
+8883ms ║║Comparison (enum) off changes_to (string) on = false (1ms)
+8885ms ║║Cancelling condition #2's schedules...
+8885ms ║║Condition #2 evaluated false (5ms)
+8887ms ║║Cancelling condition #1's schedules...
+8887ms ║║Condition group #1 evaluated false (state changed) (7ms)
+8889ms ║╚Execution stage complete. (13ms)
+8890ms ╚Event processed successfully (8890ms)
11/5/2020, 9:01:29 PM +586ms
+1ms ╔Received event [Living Room color loop].switch = on with a delay of 36ms
+94ms ║RunTime Analysis CS > 16ms > PS > 51ms > PE > 26ms > CE
+96ms ║Runtime (42114 bytes) successfully initialized in 51ms (v0.3.110.20191009) (94ms)
+104ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+105ms ║║Cancelling condition #2's schedules...
+106ms ║║Condition #2 evaluated true (5ms)
+107ms ║║Cancelling condition #1's schedules...
+108ms ║║Condition group #1 evaluated true (state changed) (6ms)
+110ms ║║Cancelling statement #3's schedules...
+127ms ║║Executed physical command [Entertainment Center].setColor([[hue:0, saturation:100, level:50]]) (8ms)
+128ms ║║Executed virtual command [Entertainment Center].setHSLColor (10ms)
+135ms ║║Executed physical command [Mantle].setColor([[hue:0, saturation:100, level:50]]) (5ms)
+136ms ║║Executed virtual command [Mantle].setHSLColor (7ms)
+142ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+148ms ║║Comparison (enum) on is (string) on = true (1ms)
+149ms ║║Cancelling condition #32's schedules...
+150ms ║║Condition #32 evaluated true (6ms)
+151ms ║║Cancelling condition #14's schedules...
+152ms ║║Condition group #14 evaluated true (state changed) (7ms)
+154ms ║║Cancelling statement #16's schedules...
+160ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+165ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (2ms)
+172ms ║║Executed physical command [Entertainment Center].setHue([0]) (5ms)
+173ms ║║Executed [Entertainment Center].setHue (6ms)
+178ms ║║Executed physical command [Mantle].setHue([0]) (3ms)
+179ms ║║Executed [Mantle].setHue (5ms)
+182ms ║║Executed virtual command [Entertainment Center, Mantle].wait (1ms)
+184ms ║║Waiting for 1000ms
+1191ms ║║Comparison (integer) 1 is_equal_to (integer) 360 = false (1ms)
+1192ms ║║Condition #20 evaluated false (5ms)
+1193ms ║║Condition group #19 evaluated false (state did not change) (6ms)
+1208ms ║║Comparison (integer) 61 is_different_than (integer) 1 = true (2ms)
+1210ms ║║Condition #34 evaluated true (14ms)
+1211ms ║║Condition group #33 evaluated true (state did not change) (15ms)
+1213ms ║║Cancelling statement #35's schedules...
+1241ms ║║Executed physical command [Living Room color loop].off() (24ms)
+1242ms ║║Executed [Living Room color loop].off (26ms)
+1248ms ║║Comparison (enum) on is (string) on = true (1ms)
+1250ms ║║Condition #32 evaluated true (5ms)
+1251ms ║║Condition group #14 evaluated true (state did not change) (6ms)
+1253ms ║║Cancelling statement #16's schedules...
+1260ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+1266ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+1273ms ║║Executed physical command [Entertainment Center].setHue([0]) (4ms)
+1274ms ║║Executed [Entertainment Center].setHue (6ms)
+1279ms ║║Executed physical command [Mantle].setHue([0]) (4ms)
+1280ms ║║Executed [Mantle].setHue (5ms)
+1283ms ║║Executed virtual command [Entertainment Center, Mantle].wait (1ms)
+1284ms ║║Waiting for 1000ms
+2291ms ║║Comparison (integer) 2 is_equal_to (integer) 360 = false (2ms)
+2293ms ║║Condition #20 evaluated false (6ms)
+2294ms ║║Condition group #19 evaluated false (state did not change) (7ms)
+2309ms ║║Comparison (integer) 0 is_different_than (integer) 2 = true (2ms)
+2311ms ║║Condition #34 evaluated true (14ms)
+2312ms ║║Condition group #33 evaluated true (state did not change) (16ms)
+2314ms ║║Cancelling statement #35's schedules...
+2336ms ║║Executed physical command [Living Room color loop].off() (18ms)
+2337ms ║║Executed [Living Room color loop].off (20ms)
+2343ms ║║Comparison (enum) on is (string) on = true (2ms)
+2344ms ║║Condition #32 evaluated true (5ms)
+2345ms ║║Condition group #14 evaluated true (state did not change) (7ms)
+2348ms ║║Cancelling statement #16's schedules...
+2355ms ║║Calculating (integer) 2 + (integer) 1 >> (integer) 3
+2360ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+2368ms ║║Executed physical command [Entertainment Center].setHue([0]) (4ms)
+2369ms ║║Executed [Entertainment Center].setHue (6ms)
+2374ms ║║Executed physical command [Mantle].setHue([0]) (4ms)
+2375ms ║║Executed [Mantle].setHue (6ms)
+2378ms ║║Executed virtual command [Entertainment Center, Mantle].wait (0ms)
+2379ms ║║Waiting for 1000ms
+3386ms ║║Comparison (integer) 3 is_equal_to (integer) 360 = false (2ms)
+3388ms ║║Condition #20 evaluated false (5ms)
+3389ms ║║Condition group #19 evaluated false (state did not change) (7ms)
+3404ms ║║Comparison (integer) 0 is_different_than (integer) 3 = true (1ms)
+3405ms ║║Condition #34 evaluated true (13ms)
+3407ms ║║Condition group #33 evaluated true (state did not change) (15ms)
+3409ms ║║Cancelling statement #35's schedules...
+3430ms ║║Executed physical command [Living Room color loop].off() (18ms)
+3431ms ║║Executed [Living Room color loop].off (20ms)
+3437ms ║║Comparison (enum) on is (string) on = true (1ms)
+3439ms ║║Condition #32 evaluated true (6ms)
+3440ms ║║Condition group #14 evaluated true (state did not change) (7ms)
+3443ms ║║Cancelling statement #16's schedules...
+3450ms ║║Calculating (integer) 3 + (integer) 1 >> (integer) 4
+3456ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+3463ms ║║Executed physical command [Entertainment Center].setHue([1]) (4ms)
+3464ms ║║Executed [Entertainment Center].setHue (6ms)
+3469ms ║║Executed physical command [Mantle].setHue([1]) (3ms)
+3470ms ║║Executed [Mantle].setHue (5ms)
+3474ms ║║Executed virtual command [Entertainment Center, Mantle].wait (0ms)
+3475ms ║║Waiting for 1000ms
+4508ms ║║Comparison (integer) 4 is_equal_to (integer) 360 = false (1ms)
+4510ms ║║Condition #20 evaluated false (5ms)
+4511ms ║║Condition group #19 evaluated false (state did not change) (7ms)
+4537ms ║║Comparison (integer) 3 is_different_than (integer) 4 = true (1ms)
+4539ms ║║Condition #34 evaluated true (25ms)
+4540ms ║║Condition group #33 evaluated true (state did not change) (27ms)
+4542ms ║║Cancelling statement #35's schedules...
+4563ms ║║Executed physical command [Living Room color loop].off() (18ms)
+4564ms ║║Executed [Living Room color loop].off (20ms)
+4570ms ║║Comparison (enum) on is (string) on = true (2ms)
+4571ms ║║Condition #32 evaluated true (5ms)
+4572ms ║║Condition group #14 evaluated true (state did not change) (6ms)
+4574ms ║║Cancelling statement #16's schedules...
+4582ms ║║Calculating (integer) 4 + (integer) 1 >> (integer) 5
+4586ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+4594ms ║║Executed physical command [Entertainment Center].setHue([1]) (5ms)
+4595ms ║║Executed [Entertainment Center].setHue (6ms)
+4600ms ║║Executed physical command [Mantle].setHue([1]) (4ms)
+4601ms ║║Executed [Mantle].setHue (5ms)
+4604ms ║║Executed virtual command [Entertainment Center, Mantle].wait (0ms)
+4605ms ║║Waiting for 1000ms
+5611ms ║║Comparison (integer) 5 is_equal_to (integer) 360 = false (1ms)
+5613ms ║║Condition #20 evaluated false (5ms)
+5614ms ║║Condition group #19 evaluated false (state did not change) (6ms)
+5627ms ║║Comparison (integer) 3 is_different_than (integer) 5 = true (1ms)
+5629ms ║║Condition #34 evaluated true (13ms)
+5630ms ║║Condition group #33 evaluated true (state did not change) (14ms)
+5632ms ║║Cancelling statement #35's schedules...
+5660ms ║║Executed physical command [Living Room color loop].off() (24ms)
+5661ms ║║Executed [Living Room color loop].off (26ms)
+5666ms ║║Comparison (enum) on is (string) on = true (1ms)
+5668ms ║║Condition #32 evaluated true (5ms)
+5669ms ║║Condition group #14 evaluated true (state did not change) (7ms)
+5671ms ║║Cancelling statement #16's schedules...
+5678ms ║║Calculating (integer) 5 + (integer) 1 >> (integer) 6
+5682ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+5689ms ║║Executed physical command [Entertainment Center].setHue([1]) (4ms)
+5690ms ║║Executed [Entertainment Center].setHue (6ms)
+5695ms ║║Executed physical command [Mantle].setHue([1]) (4ms)
+5696ms ║║Executed [Mantle].setHue (4ms)
+5699ms ║║Executed virtual command [Entertainment Center, Mantle].wait (0ms)
+5699ms ║║Waiting for 1000ms
+6705ms ║║Comparison (integer) 6 is_equal_to (integer) 360 = false (1ms)
+6707ms ║║Condition #20 evaluated false (5ms)
+6708ms ║║Condition group #19 evaluated false (state did not change) (6ms)
+6724ms ║║Comparison (integer) 3 is_different_than (integer) 6 = true (1ms)
+6725ms ║║Condition #34 evaluated true (14ms)
+6726ms ║║Condition group #33 evaluated true (state did not change) (16ms)
+6728ms ║║Cancelling statement #35's schedules...
+6749ms ║║Executed physical command [Living Room color loop].off() (18ms)
+6750ms ║║Executed [Living Room color loop].off (20ms)
+6756ms ║║Comparison (enum) on is (string) on = true (1ms)
+6757ms ║║Condition #32 evaluated true (5ms)
+6758ms ║║Condition group #14 evaluated true (state did not change) (6ms)
+6760ms ║║Cancelling statement #16's schedules...
+6766ms ║║Calculating (integer) 6 + (integer) 1 >> (integer) 7
+6771ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (2ms)
+6778ms ║║Executed physical command [Entertainment Center].setHue([1]) (5ms)
+6779ms ║║Executed [Entertainment Center].setHue (5ms)
+6784ms ║║Executed physical command [Mantle].setHue([1]) (3ms)
+6785ms ║║Executed [Mantle].setHue (6ms)
+6788ms ║║Executed virtual command [Entertainment Center, Mantle].wait (0ms)
+6789ms ║║Waiting for 1000ms
+7795ms ║║Comparison (integer) 7 is_equal_to (integer) 360 = false (1ms)
+7797ms ║║Condition #20 evaluated false (4ms)
+7798ms ║║Condition group #19 evaluated false (state did not change) (6ms)
+7812ms ║║Comparison (integer) 3 is_different_than (integer) 7 = true (1ms)
+7814ms ║║Condition #34 evaluated true (14ms)
+7815ms ║║Condition group #33 evaluated true (state did not change) (15ms)
+7817ms ║║Cancelling statement #35's schedules...
+7837ms ║║Executed physical command [Living Room color loop].off() (18ms)
+7838ms ║║Executed [Living Room color loop].off (20ms)
+7844ms ║║Comparison (enum) on is (string) on = true (1ms)
+7845ms ║║Condition #32 evaluated true (5ms)
+7846ms ║║Condition group #14 evaluated true (state did not change) (6ms)
+7848ms ║║Cancelling statement #16's schedules...
+7855ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8
+7859ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+7866ms ║║Executed physical command [Entertainment Center].setHue([2]) (4ms)
+7867ms ║║Executed [Entertainment Center].setHue (6ms)
+7910ms ║║Executed physical command [Mantle].setHue([2]) (41ms)
+7916ms ║║Executed [Mantle].setHue (48ms)
+7919ms ║║Executed virtual command [Entertainment Center, Mantle].wait (1ms)
+7920ms ║║Waiting for 1000ms
+8926ms ║║Comparison (integer) 8 is_equal_to (integer) 360 = false (1ms)
+8928ms ║║Condition #20 evaluated false (4ms)
+8929ms ║║Condition group #19 evaluated false (state did not change) (5ms)
+8943ms ║║Comparison (integer) 7 is_different_than (integer) 8 = true (1ms)
+8944ms ║║Condition #34 evaluated true (13ms)
+8945ms ║║Condition group #33 evaluated true (state did not change) (14ms)
+8947ms ║║Cancelling statement #35's schedules...
+8967ms ║║Executed physical command [Living Room color loop].off() (17ms)
+8968ms ║║Executed [Living Room color loop].off (19ms)
+8973ms ║║Comparison (enum) on is (string) on = true (1ms)
+8975ms ║║Condition #32 evaluated true (5ms)
+8976ms ║║Condition group #14 evaluated true (state did not change) (6ms)
+8978ms ║║Cancelling statement #16's schedules...
+8984ms ║║Calculating (integer) 8 + (integer) 1 >> (integer) 9
+8989ms ║║Executed virtual command [Entertainment Center, Mantle].setVariable (3ms)
+8996ms ║║Executed physical command [Entertainment Center].setHue([2]) (4ms)
+8997ms ║║Executed [Entertainment Center].setHue (5ms)
+9002ms ║║Executed physical command [Mantle].setHue([2]) (4ms)
+9003ms ║║Executed [Mantle].setHue (5ms)
+9006ms ║║Executed virtual command [Entertainment Center, Mantle].wait (0ms)
+9007ms ║║Requesting a wake up for Thu, Nov 5 2020 @ 9:01:39 PM MST (in 1.0s)
+9011ms ║╚Execution stage complete. (8914ms)
+9012ms ║Setting up scheduled job for Thu, Nov 5 2020 @ 9:01:39 PM MST (in 1s)
+9018ms ╚Event processed successfully (9018ms)
