When Echo Speaks was working in ST, I used the syntax above to compare two devices. I have moved to webcore in Hubitat so that I can get Echo Speaks again. Now the original syntax will not work.
Comparing devices syntax
I would check in the webcore main app that you have those devices enabled for webcore to use on HE.
Usually there is an attribute after the : in the expression
Is there a reason you are comparing it to an expression instead of just selecting a physical device? Even if you want to use an expression you should be able to delete the : as it is just trying to help you out assuming you are specifying an attribute.
Yes, they are there.
Selecting a physical device makes me choose an attribute. I just want to compare the two devices. Ultimately, I created a variable for each device that I want to compare and it allowed me to use those variables without choosing an attribute. Sloppy, but it works.
Maybe its a ST vs hubitat thing but in ST when comparing a device variable to another physical device, it does NOT require a attribute
I think you are correct. Before HE, I could use the device name without being forced to choose an attribute. BUT, I had to use the Expression field to attain that. Someone here assisted me with that way back when. Just cannot find that post again.
