Wrote a piston which is supposed to only run if I execute it - no triggers. Don’t understand why the piston is firing in full when a switch is flicked.
To allow me to manually turn on the Virtual Device (switch) “Alarm Contact 2” without actually firing the piston.
As per the lightning bolt, it appears the action of turning the switch on is being treat as a trigger.
I expected the code
if switch x is on
do y
endif
…to do nothing. I expected the piston to actually fire up if I used the code
if switch x changes to on
do y
endif
so at the moment, it appears that there’s absolutely no difference between either approach.
Has my understanding really been that flawed for this time, or has something broken somewhere ?
Cheers!
n/a due to simplicity / theoretical question.
