I’m using the callbacks plugin in Kodi to send playing status updates to Smartthings. This particular piston turns on the lights when the playing status changes to stopped. I only want this happen if a movie was stopped (not a tv show, music, etc.) Kodi sends an event called currentPlayingType called movie when a movie is started (as shown in the logs). So my piston looks at the currentPlayingType and if it was movie for at least one second (I’ve tried longer time frames). This used to work perfectly even after migrating to the new smartthings app then it just stopped working within the last couple of weeks. If I remove the currentPlayingType from the if statement then it works so something seems to be broken with the comparison of the previous currentPlayingType event.
The lights should turn on when a movie is stopped, but not anything else.
The lights do not turn on when a movie is stopped. I’m not sure if it’s because the currentPlayingType event that updates the status to none is received before the status event of stopped and I don’t know if that’s what the log looked like when it was working.
11/4/2020, 11:29:28 PM +582ms
+2ms ╔Received event [Shield].status = stopped with a delay of 58ms
+10111ms ║RunTime Analysis CS > 17ms > PS > 10053ms > PE > 41ms > CE
+10112ms ║Piston waited at a semaphore for 10015ms
+10114ms ║Runtime (38183 bytes) successfully initialized in 10053ms (v0.3.110.20191009) (10112ms)
+10115ms ║╔Execution stage started
+10122ms ║║Comparison (string) stopped is (string) stopped = true (1ms)
+10123ms ║║Condition #8 evaluated true (4ms)
+10156ms ║║Comparison (string) None was (string) movie = false (20ms)
+10157ms ║║Condition #9 evaluated false (33ms)
+10158ms ║║Condition group #1 evaluated false (state did not change) (39ms)
+10159ms ║╚Execution stage complete. (44ms)
+10160ms ╚Event processed successfully (10160ms)
11/4/2020, 11:29:28 PM +578ms
+0ms ╔Received event [Shield].currentPlayingType = None with a delay of 41ms
+70ms ║RunTime Analysis CS > 15ms > PS > 24ms > PE > 32ms > CE
+72ms ║Runtime (38112 bytes) successfully initialized in 24ms (v0.3.110.20191009) (71ms)
+85ms ║║Comparison (string) stopped is (string) stopped = true (2ms)
+86ms ║║Cancelling condition #8’s schedules…
+87ms ║║Condition #8 evaluated true (10ms)
+163ms ║║Comparison (string) None was (string) movie = false (73ms)
+165ms ║║Condition #9 evaluated false (77ms)
+166ms ║║Condition group #1 evaluated false (state did not change) (89ms)
+168ms ║╚Execution stage complete. (94ms)
+169ms ╚Event processed successfully (168ms)
11/4/2020, 11:27:14 PM +695ms
+2ms ╔Received event [Shield].currentPlayingType = movie with a delay of 61ms
+93ms ║RunTime Analysis CS > 20ms > PS > 32ms > PE > 41ms > CE
+96ms ║Runtime (38113 bytes) successfully initialized in 32ms (v0.3.110.20191009) (94ms)
+109ms ║║Comparison (string) playing is (string) stopped = false (1ms)
+111ms ║║Condition #8 evaluated false (10ms)
+112ms ║║Condition group #1 evaluated false (state did not change) (12ms)
+113ms ║╚Execution stage complete. (17ms)
+114ms ╚Event processed successfully (114ms)
11/4/2020, 11:27:13 PM +596ms
+1ms ╔Received event [Shield].status = playing with a delay of 46ms
+73ms ║RunTime Analysis CS > 16ms > PS > 25ms > PE > 31ms > CE
+75ms ║Runtime (38102 bytes) successfully initialized in 25ms (v0.3.110.20191009) (74ms)
+76ms ║╔Execution stage started
+84ms ║║Comparison (string) playing is (string) stopped = false (1ms)
+85ms ║║Cancelling condition #8’s schedules…
+86ms ║║Condition #8 evaluated false (6ms)
+87ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+89ms ║╚Execution stage complete. (14ms)
+90ms ╚Event processed successfully (90ms)
