Piston design locks front door lock after 180 seconds if the door sensor is closed and the lock open (or unknown status). Piston worked correctly for the past many months; suddenly in the past week or so, it is locking the door even if the contact sensor is open.
I will attach logs later.
Door lock should remain unlocked if the door sensor is open.
The lock is occasionally locking, even when the sensor is open.
Sensor record shows no sign that it ever appeared closed while these errors occurred.
4) Post a Green Snapshot of the piston![image|45x37])
(UPLOAD YOUR IMAGE HERE)
