Confirming garage door is open
After garage door sensor changes to open the “garage door one is open” piston will not run
Once the garage door sensor changes to open I want the “garage door is open” piston to run
everything works except that
**4) Post a Green Snapshot of the piston![image|45x37](
+1ms ╔Received event [Garage door 1 sensor].contact = open with a delay of 9ms
+51ms ║RunTime Analysis CS > 21ms > PS > 6ms > PE > 24ms > CE
+54ms ║Runtime (42257 bytes) successfully initialized in 6ms (v0.3.110.20191009) (52ms)
+55ms ║╔Execution stage started
+62ms ║║Comparison (string) null executes (string) open garage door one = false (2ms)
+63ms ║║Cancelling condition #3’s schedules…
+64ms ║║Condition #3 evaluated false (5ms)
+65ms ║║Cancelling condition #1’s schedules…
+66ms ║║Condition group #1 evaluated false (state changed) (7ms)
+69ms ║║Condition group #14 evaluated true (state did not change) (0ms)
+71ms ║║Cancelling statement #31’s schedules…
+72ms ║║Executed virtual command cancelTasks (0ms)
+75ms ║╚Execution stage complete. (19ms)
+76ms ╚Event processed successfully (76ms)
3/22/2020, 8:10:31 PM +584ms
+1ms ╔Received event [Home].ifttt = open garage door one with a delay of 37ms
+38ms ║RunTime Analysis CS > 15ms > PS > 4ms > PE > 19ms > CE
+41ms ║Runtime (42242 bytes) successfully initialized in 4ms (v0.3.110.20191009) (39ms)
+42ms ║╔Execution stage started
+48ms ║║Comparison (string) open garage door one executes (string) open garage door one = true (1ms)
+50ms ║║Cancelling condition #3’s schedules…
+51ms ║║Condition #3 evaluated true (4ms)
+52ms ║║Cancelling condition #1’s schedules…
+52ms ║║Condition group #1 evaluated true (state changed) (6ms)
+61ms ║║Comparison (enum) closed is (string) open = false (1ms)
+63ms ║║Condition #4 evaluated false (9ms)
+64ms ║║Condition group #2 evaluated false (state did not change) (10ms)
+72ms ║║Comparison (enum) present is (string) present = true (1ms)
+73ms ║║Condition #24 evaluated true (7ms)
+74ms ║║Condition group #8 evaluated true (state did not change) (8ms)
+77ms ║║Cancelling statement #9’s schedules…
+168ms ║║Executed virtual command iftttMaker (89ms)
+171ms ║║Cancelling statement #11’s schedules…
+885ms ║║Executed physical command [Echo - *********].speak([garage door one is opening]) (707ms)
+886ms ║║Executed [Echo - **********].speak (709ms)
+894ms ║║Condition #34 evaluated false (6ms)
+895ms ║║Condition group #27 evaluated false (state did not change) (7ms)
+898ms ║║Condition group #33 evaluated true (state did not change) (1ms)
+901ms ║║Condition group #13 evaluated true (state did not change) (1ms)
+904ms ║║Condition group #14 evaluated true (state did not change) (0ms)
+906ms ║║Cancelling statement #31’s schedules…
+908ms ║║Executed virtual command cancelTasks (0ms)
+912ms ║╚Execution stage complete. (870ms)
+913ms ╚Event processed successfully (913ms)
This piston ran at 8:10:31 PM due to an IFTTT trigger…
At that time, Contact Sensor 1 was closed, so no speak command was sent…
… so it jumped to the ELSE block…
… and since Presence Sensor 1 was present, it sent a command to IFTTT, Speak etc… but then it checks to see if Contact Sensor 1 changes to open… which is impossible. (two triggers can not usually happen at the same instant)
I think that you should change that last trigger (line 43) into a condition, such as:
IF Contact Sensor 1 IS open
You may also need to move the “WAIT 10 seconds” up a few lines… (Right before that IF)
IE: you do not want to check the status of the door until after ten seconds has passed.
