Webcore newbie here and I’m sure this is a simple programming error.
The device ‘Under counter LEDs’ is not turning on and off when the device ‘Bar Main Lights’ is turned on and off.
When the ‘Bar Main Lights’ are turned on or off I want the ‘Under counter LED lights’ to turn on and off. There is no physical switch for the LED tape lights which are connected via zigbee. They are working and can turn them on and off with a simple piston which just toggles the on/off state.
The piston is detecting the main lights being turned on and off as I can see the action in the logs, but the LED tape lights are not responding.
4/20/2021, 8:11:10 AM +941ms
+1ms ╔Received event [Bar Main Lights].switch = off with a delay of 60ms
+37ms ║RunTime Analysis CS > 20ms > PS > 6ms > PE > 12ms > CE
+40ms ║Runtime (37095 bytes) successfully initialized in 6ms (v0.3.113.20210203) (38ms)
+41ms ║╔Execution stage started
+48ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+50ms ║║Condition #2 evaluated false (5ms)
+51ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+57ms ║║Comparison (enum) off changes_to (string) off = false (0ms)
+58ms ║║Condition #6 evaluated false (4ms)
+59ms ║║Condition group #5 evaluated false (state did not change) (6ms)
+61ms ║╚Execution stage complete. (20ms)
+62ms ╚Event processed successfully (62ms)
