Not sure how to get heater to stay on for 30 minutes or until temperature reaches certain value
I’d like the heater to come on if the temperature of motion sensor 4 <= 22 degrees, then either stay on for 30 minutes or until the temperature of motion sensor 4 is >=24 degrees, which ever comes first
No idea how to code testing for either of 2 conditions to be met turn the heater off
3/10/2019, 20:30:11 +939ms
+1ms ╔Received event [My home].test = 1570131011937 with a delay of 2ms
+92ms ║RunTime Analysis CS > 24ms > PS > 44ms > PE > 23ms > CE
+95ms ║Runtime (37337 bytes) successfully initialized in 44ms (v0.3.10e.20190628) (90ms)
+116ms ║║Comparison (time) 73812043 is_between (time) 21600000 … (time) 64800000 = false (10ms)
+119ms ║║Condition #2 evaluated false (15ms)
+129ms ║║Cancelling statement #2’s schedules…
+137ms ║║Requesting time schedule wake up at Fri, Oct 4 2019 @ 6:00:00 AM BST
+150ms ║║Condition group #1 evaluated false (state did not change) (48ms)
+185ms ║╚Execution stage complete. (89ms)
+195ms ║Setting up scheduled job for Fri, Oct 4 2019 @ 6:00:00 AM BST (in 34187.867s)
+206ms ╚Event processed successfully (206ms)
