How can I read the status from a device into a variable? I want to make a piston that turns on the HAC when the door is closed, but I need to read the status of the HAC in the beginning. I’m new to WC and would be happy for any help.
Controlling HAC
eibyer
You need to define the variable. Next is to create the task that will set the variable, something similar to below.
or using an Expression:
