Convert a negative number into a positive number
I have a variable that often changes, but is always a negative number.
ie: -36 or -22 etc
I would like to make a second variable with the positive version of the number
ie: -36 into 36, or -22 into 22
This sounds simple, but I cannot find any reference to this anywhere.
If num < 0
Set newnum num*(-1)
End if
Or…
abs
Syntax
decimal abs(decimal value)
Returns
Returns the absolute value of the argument (e.g., remove negative sign for negative values).
Thanks for the quick reply. abs was what I was looking for… although I cannot believe I forgot that multiplying by -1 would work as well. Thanks @Gopack2!
