I have many Cooper (Eaton) Aspire 3-way switches with Aux switches . They should, but don’t sync.
I need them to sync with or without a button press or when I tell Alexa to change them. If I change the Main switch, I want the Aux to reflect the change. Vice-versa. Also, if I use Alexa to change them, I want the physical switches (both) to reflect the change. Currently, only the main switch does.
Currently, only the ‘main’ switch in each situation works. I can change the dimmers on them, but the ‘aux’ switches don’t refelct what’s done with the main. Also, when the Aux switches are pressed, they turn on the lights, but won’t reflect the level or state of the main switch, nor will they turn off the lights. Only on.
