Copy over Philips Hue Scenes
Not sure if this is the correct place to ask this…
I currently have a LOT of scenes already setup in the Philips Hue app, is there a way I can covert these so that WebCoRE can activate them.
I’m thinking maybe a switch for each one, and then I can just toggle them on or off?
Are you looking for some sort of auto-migration tool? If so, that doesn’t exist. But otherwise you have a couple of options:
  1. Set up the Scene in SmartThings along with a routine that sets it.You can then use webcore to trigger that routine whenever/however you like.
  2. You can have webcore directly do what you want at a certain time/based upon a certain trigger. it would just mean setting each piston up to reflect your current Hue scene.
I found a post from a few months ago of a SmartApp and DHs that someone created that will allow you to import your scenes into WebCoRE
Importing scenes would be great, can you help us find that post?
Please take a look at this
If you need any help let me know
