The condition highlighted in the below trace as red is evaluating as false, even though the intent is for it to evaluate as true. Have i used the Group condition incorrectly or something to where this does not evaluate in the way intended?
The intent is for the condition to evaluate to true IF: activeAlertSound is true AND (either activeAlertAwake is true OR switch 13 is off). That is, if activeAlertSound is true, the condition should evaluate to true if either activeAlertAwake is true or switch 13 is off.
The condition however is evaluating to FALSE, as shown by the red trace. In this screenshot, the global variable activeAlertSound is true in the variables section of webcore. The global variable activeAlertAwake is false. And switch 13 is indeed off.
| +1ms | ╔Received event [Home].mode = Alert with a delay of 154ms |
| +317ms | ║RunTime Analysis CS > 22ms > PS > 201ms > PE > 93ms > CE |
| +320ms | ║Runtime (46125 bytes) successfully initialized in 201ms (v0.3.10a.20190223) (318ms) |
| +321ms | ║╔Execution stage started |
| +331ms | ║║Comparison (string) :c7630a3b5502e2a9c13dbc553e985507: changes_to (string) :c7630a3b5502e2a9c13dbc553e985507: = true (1ms) |
| +333ms | ║║Cancelling condition #8’s schedules… |
| +334ms | ║║Condition #8 evaluated true (7ms) |
| +336ms | ║║Cancelling condition #1’s schedules… |
| +337ms | ║║Condition group #1 evaluated true (state changed) (10ms) |
| +343ms | ║║Cancelling statement #4’s schedules… |
| +442ms | ║║Executed virtual command [Kitchen Pendant].saveStateGlobally (90ms) |
| +446ms | ║║Cancelling statement #6’s schedules… |
| +468ms | ║║Executed virtual command [Living Room Lamp Right].saveStateGlobally (15ms) |
| +473ms | ║║Cancelling statement #42’s schedules… |
| +496ms | ║║Executed virtual command [Sarah’s Lamp].saveStateGlobally (14ms) |
| +506ms | ║║Comparison (boolean) false is (boolean) true = false (2ms) |
| +509ms | ║║Condition #52 evaluated false (7ms) |
| +510ms | ║║Condition group #33 evaluated false (state did not change) (10ms) |
| +514ms | ║║Cancelling statement #44’s schedules… |
| +528ms | ║║Executed virtual command executePiston (9ms) |
| +532ms | ║╚Execution stage complete. (211ms) |
| +534ms | ╚Event processed successfully (533ms) |
Now i just have to figure out how to modify it… If i wait until the last line of the calling piston to change the Location Mode to Alert, would that do it?
