Hello all,
This is my first post here on webcore, and I have been playing with home automation now for several years at a basic level. I have experience in programming industrial air conditioning and lighting automation, however the programming language uses graphic blocks that performed set functions stringed together, not text. Any help with the piston described below would be greatly appreciated, and thank you all in advance for your help!
I need a timer counter function that will be variable based upon a runtime of a specific input switching on and off throughout the day(24 hour period). I then need to roll that counted time over to the following day to be used as a runtime for another piece of equipment.
I do not know how to write the proper timer sequence, but believe it should look something like:
Equipment 1
start:time now (time 1)
end:time now (time 2)
time 2 - time1 = integer1
(this will switch on and off throughout the day a few times, time needs to accumulate by the end of the day)
Equipment 2
start:time=now(start time will be scheduled)
stop time=start time+integer1
I don’t know how to properly write the sequence, or if I’m even on the right track
(UPLOAD YOUR IMAGE HERE)
In case anyone is curios, here’s the grand scheme of things. I have a pool that is heated by way of a refrigerant to water heat exchanger. When this is enabled, the runtime of the AC performs the filtering duty that I normally have scheduled, so I’m looking to offset the filtering schedule for only the remaining time required. I can do this manually right now, but I’m looking to fully automate it, and further down the road trim the filtering time based upon the lux and pool temperature.
