I want to know which lock has a low battery but when I log currenteventdevice, it lists the name of my hub, not either of the locks
one of the names of the two lock devices that triggered the event should be printed
the name of the hub ‘home’ is printed.
4/19/2020, 7:36:47 AM +593ms
+1ms ╔Received event [Home].test = 1587307007593 with a delay of 0ms
+92ms ║RunTime Analysis CS > 18ms > PS > 52ms > PE > 21ms > CE
+94ms ║Runtime (37688 bytes) successfully initialized in 52ms (v0.3.110.20191009) (92ms)
+114ms ║║Comparison (integer) 30 is_less_than (integer) 50 = true (2ms)
+116ms ║║Condition #2 evaluated true (16ms)
+117ms ║║Condition group #1 evaluated true (state did not change) (18ms)
+120ms ║║Cancelling statement #3’s schedules…
+127ms ║║Calculating (string) Home + (string) is low battery >> (string) Home is low battery
+131ms ║║Home is low battery
+132ms ║║Executed virtual command log (2ms)
+134ms ║╚Execution stage complete. (39ms)
