I used a previous piston import (fh5r), and updated the device to just one to see if I could get it to work. It always comes back with an error: An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
To run without the error
It is creating the error: An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
1/20/2021, 9:43:30 AM +156ms
+0ms ╔Received event [My home].test = 1611153810155 with a delay of 0ms
+62ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 35ms > CE
+65ms ║Runtime (54314 bytes) successfully initialized in 6ms (v0.3.110.20191009) (64ms)
+73ms ║║Cancelling statement #206’s schedules…
+89ms ║║Calculating (decimal) 1.611153810155E12 - (decimal) 1.0 >> (decimal) 1.611153810154E12
+699ms ║║__An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object__
+710ms ║╚Execution stage complete. (643ms)
+723ms ║Setting up scheduled job for Wed, Jan 20 2021 @ 9:45:41 AM EST (in 130.622s)
+731ms ╚Event processed successfully (731ms)
1/20/2021, 9:35:48 AM +247ms
+780ms ║**An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object**
