Yes it is, I was careful to do that. I currently have you version running for 15 minute intervals, but the history on the switch it is running on 8 minute intervals before it stopped, motion just restarted it so I will see what it does.
So yours isnt ever turning the switch on for whatever reason, and yes I am using a different relay to test this one with.
11/3/2020, 4:56:52 PM +438ms
+1ms ╔Received event [Motion Living Room].motion = inactive with a delay of 33ms
+69ms ║RunTime Analysis CS > 14ms > PS > 38ms > PE > 16ms > CE
+71ms ║Runtime (38492 bytes) successfully initialized in 38ms (v0.3.110.20191009) (69ms)
+72ms ║╔Execution stage started
+79ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+80ms ║║Cancelling condition #2's schedules...
+81ms ║║Condition #2 evaluated false (5ms)
+82ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+84ms ║╚Execution stage complete. (12ms)
+85ms ╚Event processed successfully (85ms)
11/3/2020, 4:56:35 PM +443ms
+1ms ╔Received event [Motion Living Room].motion = active with a delay of 32ms
+75ms ║RunTime Analysis CS > 19ms > PS > 37ms > PE > 19ms > CE
+78ms ║Runtime (38493 bytes) successfully initialized in 37ms (v0.3.110.20191009) (75ms)
+86ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+88ms ║║Cancelling condition #2's schedules...
+89ms ║║Condition #2 evaluated true (6ms)
+93ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+94ms ║║Condition #13 evaluated false (4ms)
+95ms ║║Condition group #1 evaluated false (state did not change) (12ms)
+97ms ║╚Execution stage complete. (19ms)
+99ms ╚Event processed successfully (98ms)
11/3/2020, 4:56:10 PM +201ms
+0ms ╔Received event [Motion Living Room].motion = inactive with a delay of 36ms
+83ms ║RunTime Analysis CS > 21ms > PS > 45ms > PE > 18ms > CE
+85ms ║Runtime (38492 bytes) successfully initialized in 45ms (v0.3.110.20191009) (84ms)
+87ms ║╔Execution stage started
+94ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+96ms ║║Cancelling condition #2's schedules...
+97ms ║║Condition #2 evaluated false (5ms)
+98ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+100ms ║╚Execution stage complete. (13ms)
+101ms ╚Event processed successfully (101ms)
11/3/2020, 4:55:47 PM +697ms
+1ms ╔Received event [Motion Living Room].motion = active with a delay of 33ms
+72ms ║RunTime Analysis CS > 15ms > PS > 42ms > PE > 16ms > CE
+75ms ║Runtime (38493 bytes) successfully initialized in 42ms (v0.3.110.20191009) (72ms)
+75ms ║╔Execution stage started
+83ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+84ms ║║Cancelling condition #2's schedules...
+85ms ║║Condition #2 evaluated true (5ms)
+89ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+90ms ║║Condition #13 evaluated false (4ms)
+91ms ║║Condition group #1 evaluated false (state did not change) (12ms)
+93ms ║╚Execution stage complete. (18ms)
+94ms ╚Event processed successfully (94ms)
11/3/2020, 4:55:15 PM +894ms
+1ms ╔Received event [Motion Living Room].motion = inactive with a delay of 35ms
+74ms ║RunTime Analysis CS > 13ms > PS > 46ms > PE > 15ms > CE
+76ms ║Runtime (38492 bytes) successfully initialized in 46ms (v0.3.110.20191009) (74ms)
+77ms ║╔Execution stage started
+84ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+86ms ║║Cancelling condition #2's schedules...
+86ms ║║Condition #2 evaluated false (5ms)
+87ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+89ms ║╚Execution stage complete. (12ms)
+90ms ╚Event processed successfully (90ms)
11/3/2020, 4:54:45 PM +351ms
+0ms ╔Received event [Motion Living Room].motion = active with a delay of 33ms
+61ms ║RunTime Analysis CS > 13ms > PS > 35ms > PE > 14ms > CE
+64ms ║Runtime (38493 bytes) successfully initialized in 35ms (v0.3.110.20191009) (62ms)
+65ms ║╔Execution stage started
+71ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+72ms ║║Cancelling condition #2's schedules...
+73ms ║║Condition #2 evaluated true (5ms)
+77ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+78ms ║║Condition #13 evaluated false (4ms)
+79ms ║║Condition group #1 evaluated false (state did not change) (11ms)
+81ms ║╚Execution stage complete. (16ms)
+82ms ╚Event processed successfully (81ms)
11/3/2020, 4:54:16 PM +501ms
+0ms ╔Received event [Motion Living Room].motion = inactive with a delay of 33ms
+73ms ║RunTime Analysis CS > 17ms > PS > 42ms > PE > 15ms > CE
+75ms ║Runtime (38492 bytes) successfully initialized in 42ms (v0.3.110.20191009) (74ms)
+76ms ║╔Execution stage started
+83ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+85ms ║║Condition #2 evaluated false (5ms)
+86ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+88ms ║╚Execution stage complete. (11ms)
+89ms ╚Event processed successfully (89ms)
11/3/2020, 4:52:31 PM +345ms
+2ms ╔Received event [Motion Living Room].motion = active with a delay of 38ms
+82ms ║RunTime Analysis CS > 17ms > PS > 50ms > PE > 15ms > CE
+85ms ║Runtime (38493 bytes) successfully initialized in 50ms (v0.3.110.20191009) (83ms)
+86ms ║╔Execution stage started
+94ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+95ms ║║Cancelling condition #2's schedules...
+96ms ║║Condition #2 evaluated true (6ms)
+101ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+102ms ║║Condition #13 evaluated false (5ms)
+103ms ║║Condition group #1 evaluated false (state did not change) (13ms)
+105ms ║╚Execution stage complete. (20ms)
+107ms ╚Event processed successfully (106ms)
11/3/2020, 4:02:47 PM +277ms
+66ms ║RunTime Analysis CS > 13ms > PS > 39ms > PE > 14ms > CE
+68ms ║Runtime (38492 bytes) successfully initialized in 39ms (v0.3.110.20191009) (66ms)
+69ms ║╔Execution stage started
+76ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+77ms ║║Cancelling condition #2's schedules...
+78ms ║║Condition #2 evaluated false (5ms)
+79ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+81ms ║╚Execution stage complete. (12ms)
+82ms ╚Event processed successfully (82ms)
11/3/2020, 4:02:25 PM +869ms
+1ms ╔Received event [Motion Living Room].motion = active with a delay of 38ms
+77ms ║RunTime Analysis CS > 17ms > PS > 46ms > PE > 13ms > CE
+79ms ║Runtime (38493 bytes) successfully initialized in 46ms (v0.3.110.20191009) (77ms)
+204ms ║║Comparison (enum) active changes_to (string) active = true (118ms)
+206ms ║║Cancelling condition #2's schedules...
+207ms ║║Condition #2 evaluated true (123ms)
+211ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+212ms ║║Condition #13 evaluated false (4ms)
+213ms ║║Condition group #1 evaluated false (state did not change) (129ms)
+215ms ║╚Execution stage complete. (135ms)
+216ms ╚Event processed successfully (216ms)
11/3/2020, 4:02:19 PM +831ms
+62ms ║RunTime Analysis CS > 13ms > PS > 36ms > PE > 13ms > CE
+64ms ║Runtime (38492 bytes) successfully initialized in 36ms (v0.3.110.20191009) (63ms)
+72ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+74ms ║║Cancelling condition #2's schedules...
+75ms ║║Condition #2 evaluated false (6ms)
+76ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+78ms ║╚Execution stage complete. (14ms)
+79ms ╚Event processed successfully (80ms)
11/3/2020, 4:02:01 PM +997ms
+146ms ║RunTime Analysis CS > 16ms > PS > 116ms > PE > 14ms > CE
+149ms ║Runtime (38496 bytes) successfully initialized in 116ms (v0.3.110.20191009) (146ms)
+157ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+159ms ║║Cancelling condition #2's schedules...
+160ms ║║Condition #2 evaluated true (6ms)
+164ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+166ms ║║Condition #13 evaluated false (4ms)
+167ms ║║Condition group #1 evaluated false (state did not change) (12ms)
+169ms ║╚Execution stage complete. (19ms)
+170ms ╚Event processed successfully (170ms)
11/3/2020, 4:00:31 PM +521ms
+1ms ╔Received event [Motion Living Room].motion = inactive with a delay of 40ms
+76ms ║RunTime Analysis CS > 19ms > PS > 45ms > PE > 12ms > CE
+78ms ║Runtime (38492 bytes) successfully initialized in 45ms (v0.3.110.20191009) (76ms)
+86ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+89ms ║║Condition #2 evaluated false (6ms)
+90ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+92ms ║╚Execution stage complete. (12ms)
+93ms ╚Event processed successfully (92ms)
11/3/2020, 3:59:44 PM +10ms
+1ms ╔Received event [Motion Living Room].motion = active with a delay of 29ms
+60ms ║RunTime Analysis CS > 12ms > PS > 37ms > PE > 10ms > CE
+62ms ║Runtime (38493 bytes) successfully initialized in 37ms (v0.3.110.20191009) (60ms)
+63ms ║╔Execution stage started
+69ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+71ms ║║Cancelling condition #2's schedules...
+72ms ║║Condition #2 evaluated true (5ms)
+75ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+77ms ║║Condition #13 evaluated false (4ms)
+78ms ║║Condition group #1 evaluated false (state did not change) (11ms)
+79ms ║╚Execution stage complete. (16ms)
+80ms ╚Event processed successfully (80ms)
11/3/2020, 3:58:22 PM +685ms
+67ms ║RunTime Analysis CS > 15ms > PS > 41ms > PE > 11ms > CE
+70ms ║Runtime (38492 bytes) successfully initialized in 41ms (v0.3.110.20191009) (67ms)
+70ms ║╔Execution stage started
+77ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+79ms ║║Cancelling condition #2's schedules...
+79ms ║║Condition #2 evaluated false (5ms)
+80ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+82ms ║╚Execution stage complete. (12ms)
+83ms ╚Event processed successfully (83ms)
11/3/2020, 3:57:33 PM +51ms
+1ms ╔Received event [Motion Living Room].motion = active with a delay of 36ms
+75ms ║RunTime Analysis CS > 17ms > PS > 42ms > PE > 15ms > CE
+77ms ║Runtime (38467 bytes) successfully initialized in 42ms (v0.3.110.20191009) (76ms)
+78ms ║╔Execution stage started
+84ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+87ms ║║Condition #2 evaluated true (4ms)
+90ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+91ms ║║Condition #13 evaluated false (4ms)
+92ms ║║Condition group #1 evaluated false (state did not change) (11ms)
+94ms ║╚Execution stage complete. (17ms)
+95ms ╚Event processed successfully (95ms)
I am out of replies apparently, but I did just add:
define
boolean Pump_Off = true;
end define;
I will test this
ya, I updated to your latest version, it did do that, unfortunately with the last version, it is still stopping the countdowns on new motion events, so I basically get one press every time it sees motion if I am occupying the space.
Well, I really wish I could reply, it says I have to wait 17 hours so see you on the otherside, but both of these are not working as intended.
Thanks for all the help
Ya, that is definitely the issue that is keeping this from being a simple IF THEN, its acting like a WHILE THEN. Equis script seems to be getting past that, since it runs and checks the time since the value changed, but for some reason that is triggering an ON command 2-3 times within a minute, and also firing at an odd interval like 8 minutes when its set to fire at 15 minutes.
I like the way this reads better too, but I did try doing that in one of the attempts it does get around needing to initialize the variable, I did find that in Equis script I had to add something to reset the pump state anyway, because it at one point got caught in Pumprunning = True, but outside of all the windows to trigger an ON it was running to nowhere.
Maybe I need to do this in a smartapp instead, I know enough of groovy to do it, but since they are retiring that its a waste of time I presume, and I haven’t played with Javascript
