I want to know when the last time a device was turned on/off. How do I do this in a piston? I’ve played around but can’t seem to figure it out.
Thanks
Thanks
Expressions age() and [deviceName:swiitch] would give you last event and switch status.
Edit: age([deviceName:attribute])
Thank you. I had tried age. That gives me milliseconds since the event right? So I’d need to deduct that from now which is the step I was missing.
Edit: what I just posted doesn’t make sense. Thinking …
Example…
formatDuration(age([Front Door Lock:lock]))
Output:
(expression) formatDuration(age([Front Door Lock:lock])) »»» (string) 00:37:39
Other formats here:
https://wiki.webcore.co/Functions#formatDuration
I am using this expression to get the actual date/time of the last on/off event rather than time since:
A
{$now}-(age([device :switch]))
This returns the following format:
Sat, Sep 9 2017 @ 5:55:27 PM CDT
In other places I use the following expression to format a date and time:
B
format('%s %d @ %s', $monthName, $day, $time)
This gives me the format:
September 9, 2017 @ 5:55 P.M.
I would like to transpose the results from A in to the format I get from B.
Can I do this? I cannot figure out how to do it.
EDIT: correction to the output from B above. It’s actually:
September 9 @ 5:55 P.M.
Just correcting the post so I don’t confuse others.
Try this…
formatDateTime($now-(age([Back Porch:switch])), 'MMMMM dd, yyyy @ h:mm a')
Reference: https://docs.oracle.com/javase/tutorial/i18n/format/simpleDateFormat.html
Thank you. You nailed it.
I’ve been sitting here for hours trying different things and just could not make it work.
