Day of Year function for use in an expression?
Does it exist (somewhere that I haven’t looked)?
If not, how would I go about calculating it? I’m thinking milliseconds since start of year, but I’m hoping someone has a much more elegant solution than I would probably come up with.
I believe that you’re looking for formatDateTime($now, 'D')
It is! Thank you.
Is that a “WebCore” thing, or does that flow through to Java (and hence what Java/Groovy can do, WebCore can do)?
I believe that this is a webCoRE function (which essentially calls some Groovy code) – see the webCoRE wiki on what functions are available.
The FormatDateTime section simply has a link to the Java docs at https://docs.oracle.com/javase/tutorial/i18n/format/simpleDateFormat.html
That initially confused me.
That documentation tells you all the available format strings you can use.
