I am trying to use a loop to collect all the opened contact names into a text string then send to a web request.
The variable allOpenContacts should have all the open contact names. I will make is as a message to be used to a web request.
I can see the correct value is generated into the text string “allOpenContacts”. However, after the loop, in all the after task this allOpenContacts is an empty string. No idea why it’s gone.
1/7/2022, 5:49:39 PM +868ms
+2ms ╔Received event [Overall Contact Status].contact = closed with a delay of 107ms
+77ms ║RunTime Analysis CS > 23ms > PS > 12ms > PE > 41ms > CE
+79ms ║Runtime (46901 bytes) successfully initialized in 12ms (v0.3.113.20210203) (76ms)
+87ms ║║Comparison (enum) closed changes_to (string) open = false (0ms)
+89ms ║║Cancelling condition #2’s schedules…
+90ms ║║Condition #2 evaluated false (6ms)
+91ms ║║Cancelling condition #1’s schedules…
+92ms ║║Condition group #1 evaluated false (state changed) (7ms)
+93ms ║╚Execution stage complete. (13ms)
+95ms ╚Event processed successfully (94ms)
1/7/2022, 5:49:27 PM +2ms
+0ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 0ms
+74ms ║RunTime Analysis CS > 25ms > PS > 8ms > PE > 42ms > CE
+77ms ║Runtime (46890 bytes) successfully initialized in 8ms (v0.3.113.20210203) (76ms)
+78ms ║╔Execution stage started
+100ms ║║Calculating (integer) 1 - (integer) 1 >> (integer) 0
+114ms ║║Calculating (string) + (string) open for more than three minutes. Temperature is set to sixty four degree Fahrenheit. >> (string) open for more than three minutes. Temperature is set to sixty four degree Fahrenheit.
+171ms ║║Executed virtual command sendSMSNotification (53ms)
+173ms ║╚Execution stage complete. (95ms)
+181ms ╚Event processed successfully (180ms)
1/7/2022, 5:49:26 PM +284ms
+0ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 1ms
+128ms ║RunTime Analysis CS > 37ms > PS > 8ms > PE > 83ms > CE
+131ms ║Runtime (46891 bytes) successfully initialized in 8ms (v0.3.113.20210203) (130ms)
+133ms ║╔Execution stage started
+170ms ║║Calculating (integer) 1 - (integer) 1 >> (integer) 0
+187ms ║║Calculating (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac& + (string) monkey=family-room-monkey&announcement= >> (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=family-room-monkey&announcement=
+191ms ║║Calculating (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=family-room-monkey&announcement= + (string) >> (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=family-room-monkey&announcement=
+195ms ║║Calculating (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=family-room-monkey&announcement= + (string) %20open%20for%20more%20than%20three%20minutes.%20Temperature%20is%20set%20to%20sixty%20four%20degree%20Fahrenheit. >> (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=family-room-monkey&announcement=%20open%20for%20more%20than%20three%20minutes.%20Temperature%20is%20set%20to%20sixty%20four%20degree%20Fahrenheit.
+203ms ║║Sending external web request to: api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=family-room-monkey&announcement=%20open%20for%20more%20than%20three%20minutes.%20Temperature%20is%20set%20to%20sixty%20four%20degree%20Fahrenheit.
+230ms ║║Executed virtual command httpRequest (28ms)
+231ms ║║Requesting a wake up for Fri, Jan 7 2022 @ 5:49:50 PM CST (in 24.0s)
+235ms ║╚Execution stage complete. (103ms)
+237ms ║Setting up scheduled job for Fri, Jan 7 2022 @ 5:49:50 PM CST (in 23s)
+246ms ╚Event processed successfully (246ms)
1/7/2022, 5:49:22 PM +807ms
+1ms ╔Received event [Overall Contact Status].contact = open with a delay of 104ms
+72ms ║RunTime Analysis CS > 21ms > PS > 9ms > PE > 42ms > CE
+75ms ║Runtime (45995 bytes) successfully initialized in 9ms (v0.3.113.20210203) (73ms)
+76ms ║╔Execution stage started
+85ms ║║Comparison (enum) open changes_to (string) open = true (0ms)
+86ms ║║Cancelling condition #2’s schedules…
+88ms ║║Condition #2 evaluated true (6ms)
+89ms ║║Cancelling condition #1’s schedules…
+90ms ║║Condition group #1 evaluated true (state changed) (9ms)
+93ms ║║Cancelling statement #16’s schedules…
+97ms ║║Executed virtual command setVariable (1ms)
+101ms ║║Executed virtual command setVariable (1ms)
+107ms ║║Executed virtual command setVariable (3ms)
+2292ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2295ms ║║Condition #5 evaluated false (2180ms)
+2296ms ║║Condition group #4 evaluated false (state did not change) (2182ms)
+2319ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2321ms ║║Condition #5 evaluated false (17ms)
+2323ms ║║Condition group #4 evaluated false (state did not change) (19ms)
+2343ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2346ms ║║Condition #5 evaluated false (17ms)
+2348ms ║║Condition group #4 evaluated false (state did not change) (19ms)
+2376ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2378ms ║║Condition #5 evaluated false (19ms)
+2380ms ║║Condition group #4 evaluated false (state did not change) (21ms)
+2404ms ║║Comparison (dynamic) open is (enum) open = true (2ms)
+2406ms ║║Cancelling condition #5’s schedules…
+2407ms ║║Condition #5 evaluated true (19ms)
+2409ms ║║Cancelling condition #4’s schedules…
+2410ms ║║Condition group #4 evaluated true (state changed) (23ms)
+2413ms ║║Cancelling statement #6’s schedules…
+2422ms ║║Executed virtual command setVariable (4ms)
+2428ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+2432ms ║║Executed virtual command setVariable (2ms)
+2454ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2456ms ║║Cancelling condition #5’s schedules…
+2457ms ║║Condition #5 evaluated false (18ms)
+2458ms ║║Cancelling condition #4’s schedules…
+2460ms ║║Condition group #4 evaluated false (state changed) (21ms)
+2482ms ║║Comparison (dynamic) closed is (enum) open = false (1ms)
+2484ms ║║Condition #5 evaluated false (17ms)
+2485ms ║║Condition group #4 evaluated false (state did not change) (19ms)
+2508ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2511ms ║║Condition #5 evaluated false (20ms)
+2512ms ║║Condition group #4 evaluated false (state did not change) (21ms)
+2535ms ║║Comparison (dynamic) closed is (enum) open = false (1ms)
+2536ms ║║Condition #5 evaluated false (17ms)
+2538ms ║║Condition group #4 evaluated false (state did not change) (19ms)
+2562ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2564ms ║║Condition #5 evaluated false (20ms)
+2566ms ║║Condition group #4 evaluated false (state did not change) (21ms)
+2591ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2594ms ║║Condition #5 evaluated false (20ms)
+2595ms ║║Condition group #4 evaluated false (state did not change) (22ms)
+2622ms ║║Comparison (dynamic) closed is (enum) open = false (1ms)
+2625ms ║║Condition #5 evaluated false (22ms)
+2626ms ║║Condition group #4 evaluated false (state did not change) (24ms)
+2655ms ║║Comparison (dynamic) closed is (enum) open = false (1ms)
+2658ms ║║Condition #5 evaluated false (24ms)
+2659ms ║║Condition group #4 evaluated false (state did not change) (26ms)
+2687ms ║║Comparison (dynamic) closed is (enum) open = false (1ms)
+2689ms ║║Condition #5 evaluated false (23ms)
+2690ms ║║Condition group #4 evaluated false (state did not change) (24ms)
+2719ms ║║Comparison (dynamic) closed is (enum) open = false (1ms)
+2721ms ║║Condition #5 evaluated false (22ms)
+2722ms ║║Condition group #4 evaluated false (state did not change) (25ms)
+2753ms ║║Comparison (dynamic) closed is (enum) open = false (1ms)
+2755ms ║║Condition #5 evaluated false (25ms)
+2756ms ║║Condition group #4 evaluated false (state did not change) (27ms)
+2793ms ║║Comparison (dynamic) closed is (enum) open = false (2ms)
+2795ms ║║Condition #5 evaluated false (31ms)
+2796ms ║║Condition group #4 evaluated false (state did not change) (33ms)
+2808ms ║║Calculating (integer) 1 - (integer) 1 >> (integer) 0
+2813ms ║║Cancelling statement #14’s schedules…
+2827ms ║║Calculating (string) ,%20 + (string) Family Door >> (string) ,%20Family Door
+2832ms ║║Calculating (string) == (string) >> (boolean) true
+2836ms ║║Calculating (string) + (string) Family Door >> (string) Family Door
+2840ms ║║Executed virtual command setVariable (1ms)
+2844ms ║║Cancelling statement #21’s schedules…
+2852ms ║║Calculating (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac& + (string) monkey=office-monkey&announcement= >> (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=office-monkey&announcement=
+2937ms ║║Calculating (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=office-monkey&announcement= + (string) Family Door >> (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=office-monkey&announcement=Family Door
+2940ms ║║Calculating (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=office-monkey&announcement=Family Door + (string) %20open%20for%20more%20than%20three%20minutes.%20Temperature%20is%20set%20to%20sixty%20four%20degree%20Fahrenheit. >> (string) https://api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=office-monkey&announcement=Family Door%20open%20for%20more%20than%20three%20minutes.%20Temperature%20is%20set%20to%20sixty%20four%20degree%20Fahrenheit.
+2948ms ║║Sending external web request to: api.voicemonkey.io/trigger?access_token=d83b5af572d9d56f7a5817c3d9e9660a&secret_token=27e984fd5c9fc8dd3de25016e4bbdaac&monkey=office-monkey&announcement=Family%20Door%20open%20for%20more%20than%20three%20minutes.%20Temperature%20is%20set%20to%20sixty%20four%20degree%20Fahrenheit.
+2965ms ║║Executed virtual command httpRequest (18ms)
+2967ms ║║Requesting a wake up for Fri, Jan 7 2022 @ 5:49:49 PM CST (in 24.0s)
+2971ms ║╚Execution stage complete. (2895ms)
+2972ms ║Setting up scheduled job for Fri, Jan 7 2022 @ 5:49:49 PM CST (in 23s)
+3160ms ╚Event processed successfully (3160ms)
**REMOVE BELOW AFTER READING**
