I’m trying to turn on a plug on and off in the middle of the night, but only when called by an alexa routine, and not on a regular schedule.
Alexa routine is called, virtual switch turns on to trigger the routine, actual plug turns on at 2am and off at 6.30
Alex routine turns on the switch, but the routine doesn’t trigger, and I end up with cold uncooked breakfast.
26/01/2022, 15:04:21 +106ms
+2ms ╔Received event [My home].test = 1643209461104 with a delay of 1ms
+51ms ║RunTime Analysis CS > 25ms > PS > 7ms > PE > 19ms > CE
+59ms ║Runtime (37158 bytes) successfully initialized in 7ms (v0.3.113.20210203) (54ms)
+62ms ║╔Execution stage started
+82ms ║║Comparison (enum) off is (string) on = false (2ms)
+84ms ║║Condition #2 evaluated false (17ms)
+85ms ║║Condition group #1 evaluated false (state did not change) (18ms)
+90ms ║╚Execution stage complete. (28ms)
+91ms ╚Event processed successfully (91ms)
No other logs than those from when I just tested the routine. Its not run for 2 nights now.
