What is the WebCore command/parameter that allows to retrieve information regarding how a device input was changed, that is physically by the user interacting with the device vs via a Zwave/ZigBee command?
Looking at my event log on HE, I noticed that my thermostat (Honeywell T6) reports that info. The column header in the log is called “Type” et contains “physical” when the user physically interacted with the thermostat.
Thanks.
