I have a piston that is meant to track my battery-powered devices and tell me when any of them have a low battery. It is meant to be triggered by if (<device> battery changes) but the piston never fires. This used to work until several weeks ago.
When a device’s battery changes charge level the piston should run.
The piston never runs.
There are no regular logs because the piston is never triggered. All I have is this entry from a manual test:
8/4/2020, 10:36:29 AM +604ms
+0ms ╔Received event [Home].test = 1596562589604 with a delay of 1ms
+148ms ║RunTime Analysis CS > 19ms > PS > 69ms > PE > 59ms > CE
+151ms ║Runtime (47619 bytes) successfully initialized in 69ms (v0.3.110.20191009) (149ms)
+152ms ║╔Execution stage started
+234ms ║║Condition #2 evaluated false (78ms)
+235ms ║║Condition group #1 evaluated false (state did not change) (79ms)
+237ms ║╚Execution stage complete. (86ms)
+239ms ╚Event processed successfully (239ms)
