Not really Piston design help, as the piston works fine. but last few days the “did not change” condition is failing. And all history for all my devices is missing the last 5 hours, pretty sure Samsung have been messing things up in the background again. Anybody else?
05/01/2021, 10:14:20 +296ms
+5238ms ║Error calling comparison comp_did_not_change: java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
05/01/2021, 09:39:40 +209ms
+233ms ║ Goodbye! executed so A Day Away at 9:39 on 5 of January
The device history of the offending Arrival Sensor, apparently I didn’t leave home today…
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 21:50:27: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 21:50:06: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.208.182.130:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 21:47:13: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 21:37:52: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.208.182.130:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 21:34:24: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 20:45:33: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 19:27:21: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 18:48:28: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.31.173.59:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 18:30:45: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.31.173.59:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 18:22:56: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.208.182.130:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 18:22:24: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 18:15:03: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.208.182.130:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 17:46:00: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.51.218.22:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 17:43:17: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.31.173.59:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 17:31:35: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.31.173.59:443 of 5000 ms
[4d1be930-60ad-4732-8577-78cf225abfc9](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#4d1be930-60ad-4732-8577-78cf225abfc9) 17:20:39: error ║ Error calling comparison comp_did_not_change:java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Request timed out to historianv2-eu01-euwest1.api.smartthings.com/52.31.173.59:443 of 5000 ms
