I am using the IF feature the pick which device is ON and which is OFF. The OFF list updates but not for the ON list.
that the ON list should update also
The OFF list is updating and also including the the device that is on. And the ON is not updating and is always empty.
6/30/2021, 12:15:10 PM +454ms
+6ms ╔Received event [virtual-Echo-Victor].switch = off with a delay of 56ms, canQueue: true, calledMyself: false
+15ms ║RunTime initialize > 14 LockT > 1ms > rtDT > 2ms > pistonT > 1ms (first state access 11 7 7)
+20ms ║Runtime (13088 bytes) successfully initialized in 2ms (v0.3.113.20210510_HE)
+21ms ║╔Execution stage started
+33ms ║║Condition #2 evaluated false (9ms)
+35ms ║║Condition group #1 evaluated false (state did not change) (10ms)
+44ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+48ms ║║Cancelling condition #34’s schedules…
+50ms ║║Condition #34 evaluated false (12ms)
+51ms ║║Cancelling condition #33’s schedules…
+53ms ║║Condition group #33 evaluated false (state changed) (16ms)
+56ms ║╚Execution stage complete. (36ms)
+59ms ╚Event processed successfully (55ms)
6/30/2021, 12:15:10 PM +296ms
+6ms ╔Received event [virtual-Echo-Nathalia].switch = on with a delay of 60ms, canQueue: true, calledMyself: false
+20ms ║Runtime (13084 bytes) successfully initialized in 2ms (v0.3.113.20210510_HE)
+60ms ║║Condition #2 evaluated false (36ms)
+62ms ║║Condition group #1 evaluated false (state did not change) (38ms)
+71ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+76ms ║║Condition #34 evaluated true (12ms)
+78ms ║║Condition group #33 evaluated true (state did not change) (14ms)
+79ms ║║Cancelling statement #35’s schedules…
+84ms ║║Skipped execution of physical command [virtual-Echo-Studio].off([]) because it would make no change to the device. (1ms)
+85ms ║║Executed [virtual-Echo-Studio].off (3ms)
+89ms ║║Skipped execution of physical command [virtual-Echo-Suite].off([]) because it would make no change to the device. (1ms)
+90ms ║║Executed [virtual-Echo-Suite].off (3ms)
+93ms ║║Skipped execution of physical command [virtual-Echo-TodoLugar].off([]) because it would make no change to the device. (1ms)
+94ms ║║Executed [virtual-Echo-TodoLugar].off (3ms)
+106ms ║║Executed physical command [virtual-Echo-Victor].off() (9ms)
+107ms ║║Executed [virtual-Echo-Victor].off (12ms)
+113ms ║╚Execution stage complete. (92ms)
+116ms ╚Event processed successfully (111ms)
6/30/2021, 12:14:18 PM +85ms
+6ms ╔Received event [virtual-Echo-Victor].switch = on with a delay of 84ms, canQueue: true, calledMyself: false
+16ms ║RunTime initialize > 15 LockT > 1ms > rtDT > 2ms > pistonT > 1ms (first state access 12 8 7)
+20ms ║Runtime (13080 bytes) successfully initialized in 2ms (v0.3.113.20210510_HE)
+22ms ║╔Execution stage started
+33ms ║║Cancelling condition #2’s schedules…
+34ms ║║Condition #2 evaluated false (9ms)
+36ms ║║Cancelling condition #1’s schedules…
+37ms ║║Condition group #1 evaluated false (state changed) (12ms)
+47ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+51ms ║║Cancelling condition #34’s schedules…
+53ms ║║Condition #34 evaluated true (13ms)
+54ms ║║Cancelling condition #33’s schedules…
+56ms ║║Condition group #33 evaluated true (state changed) (16ms)
+57ms ║║Cancelling statement #35’s schedules…
+62ms ║║Skipped execution of physical command [virtual-Echo-Nathalia].off([]) because it would make no change to the device. (1ms)
+64ms ║║Executed [virtual-Echo-Nathalia].off (4ms)
+67ms ║║Skipped execution of physical command [virtual-Echo-Studio].off([]) because it would make no change to the device. (1ms)
+68ms ║║Executed [virtual-Echo-Studio].off (3ms)
+71ms ║║Skipped execution of physical command [virtual-Echo-Suite].off([]) because it would make no change to the device. (1ms)
+74ms ║║Executed [virtual-Echo-Suite].off (4ms)
+77ms ║║Skipped execution of physical command [virtual-Echo-TodoLugar].off([]) because it would make no change to the device. (2ms)
+78ms ║║Executed [virtual-Echo-TodoLugar].off (3ms)
+83ms ║╚Execution stage complete. (61ms)
+85ms ╚Event processed successfully (81ms)
6/30/2021, 12:13:43 PM +557ms
+6ms ╔Received event [Playlist Casa].switch = on with a delay of 61ms, canQueue: true, calledMyself: false
+20ms ║Runtime (13071 bytes) successfully initialized in 2ms (v0.3.113.20210510_HE)
+32ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+38ms ║║Condition #2 evaluated true (13ms)
+39ms ║║Condition group #1 evaluated true (state did not change) (14ms)
+44ms ║║Comparison (enum) off is (string) on = false (1ms)
+46ms ║║Condition #4 evaluated false (5ms)
+47ms ║║Condition group #3 evaluated false (state did not change) (7ms)
+53ms ║║Comparison (enum) off is (string) on = false (2ms)
+55ms ║║Condition #10 evaluated false (5ms)
+57ms ║║Condition group #9 evaluated false (state did not change) (7ms)
+63ms ║║Comparison (enum) off is (string) on = false (1ms)
+65ms ║║Condition #16 evaluated false (5ms)
+67ms ║║Condition group #15 evaluated false (state did not change) (8ms)
+73ms ║║Comparison (enum) off is (string) on = false (1ms)
+74ms ║║Condition #22 evaluated false (6ms)
+76ms ║║Condition group #21 evaluated false (state did not change) (7ms)
+82ms ║║Comparison (enum) off is (string) on = false (1ms)
+83ms ║║Condition #28 evaluated false (6ms)
+85ms ║║Condition group #27 evaluated false (state did not change) (7ms)
+97ms ║║Condition #34 evaluated false (9ms)
+99ms ║║Condition group #33 evaluated false (state did not change) (11ms)
+103ms ║╚Execution stage complete. (81ms)
+106ms ╚Event processed successfully (102ms)
6/30/2021, 12:13:06 PM +641ms
+6ms ╔Received event [Playlist Academia].switch = on with a delay of 54ms, canQueue: true, calledMyself: false
+68ms ║RunTime initialize > 67 LockT > 1ms > rtDT > 57ms > pistonT > 56ms (first state access 9 7 60)
+73ms ║Runtime (13005 bytes) successfully initialized in 57ms (v0.3.113.20210510_HE)
+92ms ║║Comparison (enum) on changes_to (string) on = true (3ms)
+97ms ║║Cancelling condition #2’s schedules…
+99ms ║║Condition #2 evaluated true (21ms)
+101ms ║║Cancelling condition #1’s schedules…
+102ms ║║Condition group #1 evaluated true (state changed) (24ms)
+110ms ║║Comparison (enum) off is (string) on = false (2ms)
+112ms ║║Condition #4 evaluated false (8ms)
+114ms ║║Condition group #3 evaluated false (state did not change) (10ms)
+123ms ║║Comparison (enum) off is (string) on = false (1ms)
+125ms ║║Condition #10 evaluated false (8ms)
+127ms ║║Condition group #9 evaluated false (state did not change) (10ms)
+136ms ║║Comparison (enum) off is (string) on = false (1ms)
+138ms ║║Condition #16 evaluated false (8ms)
+140ms ║║Condition group #15 evaluated false (state did not change) (11ms)
+149ms ║║Comparison (enum) off is (string) on = false (1ms)
+151ms ║║Condition #22 evaluated false (9ms)
+153ms ║║Condition group #21 evaluated false (state did not change) (11ms)
+162ms ║║Comparison (enum) off is (string) on = false (1ms)
+164ms ║║Condition #28 evaluated false (9ms)
+166ms ║║Condition group #27 evaluated false (state did not change) (11ms)
+180ms ║║Condition #34 evaluated false (11ms)
+220ms ║║Condition group #33 evaluated false (state did not change) (51ms)
+225ms ║╚Execution stage complete. (150ms)
+228ms ╚Event processed successfully (223ms)
