I have suffered intermittent problems with ds18b20 temp probes connected through fibaro ubs/implant lately, partially due to hub firmware issues and partly down to bad wiring or signal degradation.
These sensors are an integral part of my customised diy central heating system. When they fail, it can sometimes take days to notice depending on the nature of the failure, for example, webcore uses the last reported value. This may not have actually updated for hours or even days. The fault is more obvious if the temps read zero degrees (CH stayed on far too long!) but frequently they just don’t provide new readings.
I’d like to use webcore to monitor say, one of the probes (periodically?), and spot if it isn’t working. That way I (or rather, the system) can take action to prevent wasted energy etc.
Note that by design, there are times when perhaps no updates are logged for a while because the temperature sometimes doesn’t fluctuate at all for quite a while, so if like a way of avoiding having this incorrectly identified as s disconnect.
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
N/a?
