Device Variable not allowing all actions. For example, I have a custom device handler that has a function called LoopOff(). If I do a with statement and manually select all the devices that I want to execute this function for, it works fine. However, if I created a device variable and put the same devices in it and then change my with to use the device variable, the custom function no longer shows up in the available actions.
My custom function should show up in the action.
LoopOff() is not showing in the action drop down
(UPLOAD YOUR IMAGE HERE)
