My SmartThings hub recently dumped all my Zigbee/Z-wave devices for some reason. I had to re-add them all, which as far as I can tell means I’ll have to go back in and re-assign every reference to those devices in all of my WC pistons. I’m also moving soon, so I’m not going to take the time to do this when I’ll basically be starting from scratch after the move with new devices, new automation needs, etc.
My question: When I set everything up the next time is there a way I can set up each device as a variable or something? My goal is to create a set up where if my hub drops a device or I replace a bulb or whatever, I can just change one reference to a device in webCoRE and all my pistons will follow. Does that make sense? Any ideas?
