I have a Piston that performs an action based on the level of my dimmer. The Piston is triggered on the Switch event and the first thing it does is capture the level value. Everything generally works fine if I turn the dimmer on and off, but if I turn the dimmer on by giving the dimmer a new value, the dimmer uses the previous off value for the condition.
If the dimmer is turned on and the end level is below 10%, set level to 10%, else do nothing. I want to read final level, after the dimming has stopped. My dimmer (GE Dimmer Switch model 3038) will fade to the desired level. I want to grab the value the dimmer will end on.
If I set my dimmer to 80%, turn it off, then set the level of the dimmer to 1% in the ST App, the Piston reads the dimmer value as 80%. Even if I put in a 5 second delay, the dimmer value is still read as 80%, where the actual values is 1%
11/15/2020, 9:07:53 PM +71ms
+103ms ║80 is the current level after the wait
+125ms ║Basement Stairs Not resetting. Current level is 80
11/15/2020, 9:07:49 PM +224ms
+112ms ║80 is the current level before the wait.
