I’m stumped. I have a piston that monitors doors and windows and sends a SMS message and triggers a phone call if doors or windows are opened when the location mode is away. The challenge is I want it to notify us only if it has been three minutes since the location mode was changed to away. I’ve tried different permutations but can’t figure it out and the piston never waits 3 minutes. I know I can do this using a variable and a wait statement but it seems like there’s probably a more straightforward approach I’m missing.
I guess I basically want something that says “send alerts if something opens when the location mode is away and it has been set to away for longer than 3 minute.” I’ve tried various comparisons for location mode (stays, stays away from, etc.) without luck.
As a note, we use a voice command to set the location mode to away as we leave, hence the need to have the piston hold off for three minutes in case someone forgets something and has to run back into the house. The screenshot shows my latest attempt.
I’m sure I’m missing something obvious but I’m missing it. Thoughts or suggestions?
Send alerts if a door or window opens AND location mode has been set to Away for three minutes or more.
The piston doesn’t wait 3 minutes before reacting to a change in a door or window sensor’s open/closed status.
