I created a piston that will turn the lights on in the bedroom if there is motion. The lights will only turn on if it is day mode AND the lights were turned on by the switch or by google. When I get up in the morning and I execute a goodmorning command on my google home, it starts a gentle wakeup that slowly illuminates the light. The problem is while the light is slowly illuminating, and then the motion sensor sees motion, the light immediatley goes to 100%.
I dont want the motion sensor to turn on the light unless its day and the ceiling light has reached 100%.
The motion sensor is immediately firing once i turn the light light on in the morning, even once it is at 1%.
(UPLOAD YOUR IMAGE HERE)
